not really "high-tech" but i dont think any of the other forums really cater to this type of mod. anyway..
i installed a voltage stabilizer and a 10 point grounding kit last night and i am very pleased with the results. the butt dyno says there is at LEAST a 5 ft/lb gain in torque across the powerband, with a substantial jump right around the middle of the RPM's. i have not been to the dyno, so no verified numbers, but i am planning to go dyno the car next week, and since it is very easy to disconnect the set, i will try to get baseline and "after" numbers posted.
install was a breeze, but since i am still using the stock airbox, location for the stabilizer was a difficult task. i ended up sticking it on top of the battery for now, but i plan to move it elsewhere when i get some more spaceunder the hood.
in case you are not familiar with this part, it basically is the same thing as a capacitor that people use for stereos, but it is designed to be used under the hood. when your car's electrical system experiences and lull or a surge, this part keeps the flow of power constant by using it's backed up current handy for ignition tasks. the MFR claims that the unit is good for about 10 HP, and they provide a dyno sheet with it, but i want to see my own results once i go to dyno it next week.
the grounding kit is a no brainer. anybody who has tinkered with this engine knows that the grounding wires that come on the car are REALLY small, and probably insuffiecient. well, i changed that with the addition of 8 more points of grounding on the battery ( there are already two on the factory battery clamp, making a total of 10.)
i grounded the head in 3 places, the chassis, the ingnition coil, the tranny, the starter, the voltage stabilizer, the two factory ground wires from the original loom and harness, and then of course, the battery terminal being the point of origin. the basic idea here is simply to provide the best ground possible to ensure full and smooth transfer of electrical current for ignition tasks. This mod also has a MFR claim of a few extra ponies, but my dyno run will tell the real truth.
I intended to run one of the cables to the alternator as well, and one to the block, but unfortunately, none of the calbes were cut long enough to reach the alternator, and the block was just too much of a pain, so that is why the head has 3 grounds on it.....
here are some pics.
