Quote: Originally Posted by westrock
I saw in the AFC tuning sticky about using the MAP signal instead of the TPS. This sounds like a great idea, though it wasn't fully explained why. So let me see if I get this right...
With the DTEC you get 4 fuel maps based on TPS position. So instead by using MAP signal you would get 4 maps based on boost levels? So you would set the first map to like 10%, which would be your vacuum map. Then 2 inbetween (like 30% and 60%), and then your final one would be at whatever your target boost is (set to like 90%). The DTEC would then interpolate the numbers like the AFC, so that as the turbo spools up or you modulate the throttle the DTEC is able to give consistant fuel delivery no matter the PSI. Does this sound about right?
Is the scale of the two voltages similar between the MAP and the TPS? Meaning the MAP goes from 0 - ~5 volts, will the DTEC be OK with that for the TPS input?
Westrock,
First of all you are getting your info from the wrong forum. The SAFC is for the apexi SAFCII. Not the DTEC. If you installed the DTEC per AGP you are good to go.
Also it is not 4 fuel "maps" it's 4 "LOAD" ranges. BTW you can edit and change the 4 load ranges to a % you choose.
Do you understand closed vs open loop mode of the ecu? Anything under 80% throttle/load is closed loop.
What setup you have and the sensory outputs from that untuned setup dictates the changes.
What is you mods?
Marion
