Old 03-28-2007, 07:40 AM   #1 (permalink)
Low05's Avatar
Member Number: 23831
Default Uego Help !!!
Last night I installed my Uego and it will not read anything other that 14.8. What did I do wrong?
S0, WGA, TurboXS Hi Performance MBC, BDJ's 3" Dump, AEM UEGO,
Autometer Oil Pressure, JMB Catch Can, NGK 4306's @ .032, Walbro 255
Mopar Blue Plate, EBAY Intake, Spike 19 Hold 16, Megan Coil Overs
Low05 is offline   Reply With Quote
Old 03-28-2007, 11:36 AM   #2 (permalink)
Low05's Avatar
anyone???
Old 05-08-2007, 11:50 PM   #3 (permalink)
Chino7385's Avatar
Member Number: 30157
Trader Rating: (21)
Did you every find the problem? Because i just got the samething today. Its stuck at 14.8
*98 Neon R/T:Too Many mods
*00 Celica GT-S:I/E,STS,S-Tech's,S2k Antenna
*04 SRT-4:AGP 50Trim Kit,S1,S2 Inj,S-AFC2,AEM Wideband,Turbo XS HPBC,PTP Direct Fit,PTP UHP-HKS SSQV,PTP 180 T-Stat,PTP CV,Maxxfab Magnaflow 3" TBE ,CoolingMist W/I 50/50 Mix M5 Nozzle,DCR Oil Mod,AEM SRI,MSD Wires,Bwoody MM's,Maddog 72%,Aeroforce Pro,255 Pump and Rewire,S-Tech's,HID's
Not installed: B&G Flash, Redstar Return Line, K-Sport CO's
Chino7385 is offline   Reply With Quote
Old 05-09-2007, 01:01 AM   #4 (permalink)
Nyt-RyDa's Avatar
Member Number: 14618
Trader Rating: (67)
Helll yea same problem here except mines is stuck at default 14.7 and won't move I too made a thread to see if I can get some help.. I triple checked everything to make sure its hooked up right.. Let me know if you guys fixed it?
>Mods<
AGP 6oTRiM ||PnP head || BC stage2 cams w/springs&retainers|| ported intake mani/ pTP 55mmtb || TiALwga7psi||AEMcai||Coolingmist w/i||DW750ccinject0rs||QW FM!C || stageONE pcm ||AEMuego||DCRoil mod||AGPdogbones||AGPuppipe w/HKSssq||BW tractionBARS||DtecFC+BC ||AGPreturnline||Needswing Ecutout||||wotBOX||ACT streetDISC clutch||BORLAexhaust||
______________
SMOKING BAD!
Nyt-RyDa is offline   Reply With Quote
Old 05-09-2007, 02:04 AM   #5 (permalink)
Chino7385's Avatar
Trader Rating: (21)
Im gonna get under the car in the mourning and look at the wiring and connector.
Old 05-09-2007, 08:13 AM   #6 (permalink)
Low05's Avatar
Double check the connections on the back of the gauge, I had done this once and decided to try it again, this time the small connection clicked and everything works fine. If you followed the How-to for where to connect the power; please go back to the How-to section and look at the critical UEGO install error. Do not splice into the black wire from the wiper fuse as this wire does not run thru the fuse and therefore the uego is not fuse protected.
Old 05-09-2007, 11:06 AM   #7 (permalink)
Nyt-RyDa's Avatar
Trader Rating: (67)
Yea I taped into the radio wire fuse... but ill double check... I think I saw it go from 14.6 to 14.7 in that case it must be really lean!!!
Old 05-09-2007, 11:24 AM   #8 (permalink)
Low05's Avatar
Try pushing hard on the connections on the back of the gauge, but not hard enough to crack the case. This can be done, I have seen others do it.
Which wies are you running on the UEGO? Are you logging with the blue and white wires?
Where did you get your ground from?
Old 05-09-2007, 01:14 PM   #9 (permalink)
Chino7385's Avatar
Trader Rating: (21)
I used a fuse holder for my power and went of the key fob fuse. I am useing the white wire for my scan gauge.
Old 05-09-2007, 01:15 PM   #10 (permalink)
Chino7385's Avatar
Trader Rating: (21)
when the car is on, it should be swithing really offten. A few times a second.
Old 05-09-2007, 01:39 PM   #11 (permalink)
Chino7385's Avatar
Trader Rating: (21)
Good call, I pushed it in and it clicked. I loooked at it last night for a second and saw it connected so i thought it was something eles. Something so simple.
Old 05-09-2007, 02:05 PM   #12 (permalink)
Low05's Avatar
I am glad I could help. I was so worried when it happend to me, I thought my gauge was bad.
Page generated in 0.18672 seconds with 13 queries
