Old 09-04-2004, 04:44 PM   #1 (permalink)
Hopper's Avatar
Member Number: 11641
Default Turboxcfuel cut defencer or map clamp and wideband?
i have like 500$ to go with and i need to get this fuel cut thing taken care of has anyone tried the turboxs fuel cut defencer?
http://www.streetrays.com/catalog/pr...3cdabf581a0e40
cuz if that will work its cheaper then a clamp and a wideband <although the wideband will be handy later down the road>
and will the mx300 wideband work without a stand alone?
it sais it works with any stand alone engine management but doesnt say if it will work without one hehe let me know what you guys/gals think
04 srt-4- wastegate,intake,exhaust,greddy spec b, full exhaust, stage 1 ecu, lotsa gauges 13.3 1/4 - sold
03 s2k- 9k rpms comptech supercharged, 7psi pulley,comptech reinforced differential housing, magnaflow exhaust,toda header,comptech flywheel,act 2600 clutch,aem standalone,325 Rwhp -
Hopper is offline   Reply With Quote
Old 09-04-2004, 05:35 PM   #2 (permalink)
Hopper's Avatar
ok did some more reading and i guess the turbo fuel cut defender is a map clamp..... so would i still have to tune it on the dyno to get the right air fuel ratio??
Old 09-04-2004, 11:54 PM   #3 (permalink)
compudaze's Avatar
Member Number: 3311
that is correct. still need to get wideband readings for proper tuning.
i like the FCD because it's designed to be ran into the cockpit. it can also be set from inside the car without a multimeter. you set your boost to the desired clamp level. for example, set you boost to 15psi. then make slight adjustments till the blue led on the fcd comes on. then you know your clamp is set to 15psi. then get to the dyno and up your boost and watch the afr.
i think it's far more expensive than other map clamps. the SS VC2 is ~$80 and homemade ones from dasmopar and aaron are ~$30-40.
2003 Flame Red SRT-4
[ AGP WGA, Voodoo IV MBC, Homemade MAP Clamp ]
compudaze is offline   Reply With Quote
Old 09-05-2004, 11:24 PM   #4 (permalink)
Nick@AGP's Avatar
Member Number: 11546
TXS FCD is a map clamp.
Nick@AGP is offline   Reply With Quote
Old 09-06-2004, 08:06 AM   #5 (permalink)
04BlueSRT's Avatar
Member Number: 3500
Trader Rating: (30)
Hopper:
Well I have one that I used for a little bit, If you want it 65 shipped and it's your's. Let me know
Later
Ed
04BlueSRT is offline   Reply With Quote
Page generated in 0.16533 seconds with 13 queries
