Old 10-27-2009, 04:37 PM   #1 (permalink)
Member Number: 75447
Default Tuning Questions
So i just bought a DSP and i am going to be tuning my car soon...is there any complications or anything to be careful of when doing so? I know it comes with the 93 octane tune, but i run 91 octane so i will have to modify it a bit i assume? And i was told about dangers if i tune it to lean or to rich? Any input would be great, Thanks!
Aimois is offline   Reply With Quote
Old 10-27-2009, 04:41 PM   #2 (permalink)
hercfe's Avatar
Member Number: 19255
you may have some lean issues with the 93 tune as it is. 91 will not help at all with the increased timing of the tune. make sure you have a wideband before you do anything.
hercfe is offline   Reply With Quote
Old 10-27-2009, 04:43 PM   #3 (permalink)
i just bought a aem wideband...what would be a normal reading on that?
Old 10-27-2009, 06:01 PM   #4 (permalink)
duster360's Avatar
Member Number: 45182
Older 93 tune don't add ANY timing, it actually removes 1-2 degrees.
Te new one in crom 9r18 adds a little below 3500rpm but still removes the 1-2 degrees up top
Old 10-27-2009, 06:02 PM   #5 (permalink)
duster360's Avatar
"Normal" A/F would be around 11.5-11.8 trending up to about 12.0-12.5 at redline.
Since you only have 91, you need to datalog Knock and adjust accordingly, keep the A/F above 11.5 though
Page generated in 0.14575 seconds with 13 queries
