Old 07-05-2008, 01:44 PM   #1 (permalink)
redteaser4's Avatar
Member Number: 48736
Trader Rating: (13)
Default tuning the dtec
I know there is a shit load of threads on this but i couldn't read everything. i jsut need to know how to tune it. i know it cant be that hard but any input would be great.
redteaser4 is offline   Reply With Quote
Old 07-05-2008, 03:01 PM   #2 (permalink)
redteaser4's Avatar
Trader Rating: (13)
bump for some info. help please.
Old 07-05-2008, 06:28 PM   #3 (permalink)
redteaser4's Avatar
Trader Rating: (13)
come on guys i know someone can explain to me how to tune this thing.
Old 07-06-2008, 10:32 AM   #4 (permalink)
redteaser4's Avatar
Trader Rating: (13)
come on guys help me out.
Old 07-06-2008, 12:08 PM   #5 (permalink)
Big Corey's Avatar
Member Number: 58459
Trader Rating: (33)
go the the maps and pull fuel as you need just make sure you save it and flash it to the pcm
AGP3147 ,QW BFMIC,Atp hard pipes,HKS bov,3 in maxfab dp without cat,greddy evo2 catback stage2,many other mods to come
FORSALE:Boomba STS & WTT:stage2 injectors for 650s
Big Corey is offline   Reply With Quote
Old 07-06-2008, 12:26 PM   #6 (permalink)
Freaky's Avatar
Member Number: 47525
whats your mods ?
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is offline   Reply With Quote
Old 07-06-2008, 03:51 PM   #7 (permalink)
redteaser4's Avatar
Trader Rating: (13)
my mods are in my sig. i know you have to pull fuel but how do you do it on the dtec. like what rpm am i supposed to pull it and how much. just trying to understand it.
Old 07-07-2008, 09:54 PM   #8 (permalink)
redteaser4's Avatar
Trader Rating: (13)
can anyone give me a little more help?
Old 07-08-2008, 12:21 AM   #9 (permalink)
Freaky's Avatar
it all depends on what your a/f 's look like `. i pull fuel in ythe 100% colum only . i still have 05 injectors so the ecu handles everything fine until wot . i upped my fuel pressure till i was getting 10.3-10.8 a/f's an started to pull fuel with the dtecfcbc. i was shooting for at least -8 because i read on here somewhere that you had to be at least -8 before you start hiding boost from your ecu. the lowest i am is a-8 an the highest i am is -10 an i'm spiking 22.9-23.2 lbs of boost with no overboost codes an the car runs strong .
Old 07-08-2008, 08:30 AM   #10 (permalink)
redteaser4's Avatar
Trader Rating: (13)
k thanks. i'll try that.
Old 07-08-2008, 02:51 PM   #11 (permalink)
Freaky's Avatar
you have to be getting more fuel than you need in order to pull fuel . keep your a/f's in the 11's unless you got a scan guage to watch knock . the dtec is not a good source for knock . i still need to get a scan guage myself . if i was you i'd get the return line with the 1-1 regulator (for every lbs of boost the regulator gives you 1 psi of fuel pressure over your set pressure )an a 255 fuel pump an i believe for a e2 your gonna need bigger injectors to max that out . hopefully somebody that knows about the e2 will chime in . good luck
Old 07-08-2008, 03:29 PM   #12 (permalink)
Member Number: 9221
Trader Rating: (18)
yeah dont pull ass loads of fuel or you will get knock. I was pulling 14% and was getting 6-7 KR.
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 07-10-2008, 11:00 PM   #13 (permalink)
redteaser4's Avatar
Trader Rating: (13)
ok now my problem is. i went to turn my gameboy on to back some fuel out and the gameboy wont even load anything. the only thing that shows up is when it says gameboy. what is the problem?
Old 07-11-2008, 01:00 AM   #14 (permalink)
Member Number: 22188
that happens to me sometimes. what i do is unplug the plugs from the dtec brain and plug them back in and it works again.
deathsite is offline   Reply With Quote
Old 07-11-2008, 04:48 PM   #15 (permalink)
redteaser4's Avatar
Trader Rating: (13)
ok thanks
Page generated in 0.19262 seconds with 11 queries
