Old 12-25-2004, 06:13 AM   #1 (permalink)
dognutz's Avatar
Member Number: 14819
Trader Rating: (15)
Default tuning AFC2 with big turbo
okay i read the sticky on it but not really helping me.. i have 50 trim .63 and fuel return kit and 750 injector.. i set feul with vac line off at 42 psi and with it on to 37psi.. my question is how the hell do you tune this thing i have AGP basic setting in it right now. and also have aem uego. how do i tune it with the uego when the af/r is all over the pleace.. dont know if anyone here can help but if you can please call me and give me some ideas. thanks
mike 240 299 7459
HOME OF THE MOST HP SRT4 ON NO SPRAY!! WITH 31psi BOOST
FOR ALL YOUR NEEDS RAGE-TEK IS THE ANSWER
Shop (954) 978-0978
Cell (954) 274-4175
http://mike-castaldo.tripod.com/
also check herehttp://home.comcast.net/~extreme1neo...ome.html-.html
dognutz is offline   Reply With Quote
Old 12-26-2004, 11:31 AM   #2 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
mike,
while the uego is definitely a nice piece, it's not all that great for tuning, as driving and watching and figuring in where to make adjustments is going to be a pain.
I'd probably suggest ditching the aem and going with something along the lines of a zeitronix. Wideband w/ datalogging capabilities. That way you can correlate the air/fuel to boost/rpm/egt and figure in which adjustments need to be made.
I'm actually in talks with zeitronix right now on getting a group buy going. Don't know how I'm going to let srtforums know about it with their advertising rules, so I'm not going to post any pricing about it here.
Glacius is offline   Reply With Quote
Old 12-26-2004, 12:06 PM   #3 (permalink)
Member Number: 2584
Trader Rating: (35)
zeitronix kinda sucks when coupled with the Profec E-01. It's 5v analog output is lopey, not completely linear like the PLX ones.
funks is offline   Reply With Quote
Old 12-26-2004, 12:59 PM   #4 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
right, but he's not running an e-01. He's using a s-afc. In that sense, I'd just run the zeitronix next to it, using a laptop for the graphical displays and then you can 100% pinpoint any problem areas and go and make adjustments. The aem just doesn't have the ability to show u the bar graphs with the gauge, as it's real time. So he has to look at the gauge while running it hard, find a problem area, look at the tach quickly to note it's place, make that adjustment and try again.
Or do 1 hard complete pull logging with the zeitronix, pinpoint problem areas, go back and make said adjustments, rinse and repeat. Extremely simply and would probably be finished in 1/8 of the time it'd take it with the aem and an afc.
Old 12-27-2004, 04:55 AM   #5 (permalink)
dognutz's Avatar
Trader Rating: (15)
thanks for the help guys. i am close but i think i will take it to someone who is better then me in tuneing thanks again.. also i have stage 2 pcm.
Page generated in 2.10758 seconds with 13 queries
