Old 06-26-2008, 03:21 PM   #16 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
Please read the following VERY carefully.
Quote: Originally Posted by sour kraut View Post
Volzwagon's have had widebands on them for quite some years. Are you telling me they aren't obd2?? Also to clarify, I NEVER said we had a wideband, I stated "the srt has a 0 to 5 volt o2 that is biased 2.5 volts. It will read as low as 9to1 and as high as 20to1." Do some reading and research before you tell people they're wrong.
Tell me if it said our car has a wideband, or that the factory o2 is a wideband, or that the factory o2 will read that range linearly. No, it doesn't say any of that!! The narrowband in our car has the voltage swing to measure that range, but it is not nearly as accurate as a wideband. I know the difference between a narrowband and a wideband.
Now that we have that straightened out, here an example of volkswagons that used widebands for the upstream and the bosch part number for it. Go ahead and call your local car parts store and verify.
01' beetle 1.8 turbo part#17053
02 to 04' bettle 1.8 turbo part#17014
sour kraut is offline   Reply With Quote
Old 06-26-2008, 03:40 PM   #17 (permalink)
Tex
Tex's Avatar
Member Number: 3622
sour kraut, there is no point arguing with these new kids, especially if you have facts. afterall, he responded look it up. that means you and i are wrong.
if the range of an o2 sensor is 13.5-16 how can we sucessfully tune for over 16:1 or even 17:1 lean cruise with the factory sensor?
-Soren Kierkegaard
Tex is online now   Reply With Quote
Old 06-26-2008, 03:53 PM   #18 (permalink)
sour kraut's Avatar
I know, but it's been a bad day and he pissed me off. I usually have a very long fuse. My one thought is, "why argue with a moderator when he can change your post????"
Old 06-26-2008, 06:46 PM   #19 (permalink)
theRTguy's Avatar
Member Number: 61370
Trader Rating: (15)
Ya, hooked up the SCANTOOL tonight, it was only ranging from 2-4 volts, there were 3 differant O2 readings on the scantool.
Guees I have to wait to buy a wideband.
Thanks for the input everyone.
2004 SRT-4 (20K Miles)DC SPorts Exhaust,MOPAR C.A.I.,AGP WGA w MBC, MOPAR STS,B WOODY Solid MM Tranny Mount.,3" D.P., 3"O2 Housing, 225/45 AZENIS, EIBACH PRO-KIT,AGP CC, Fuel Pump Re-Wire,180 Degree T-Stat,Fan Re-Wire,APEXI NEO, UEGO, N2MB W.O.T. BOX w/2 Step,AEROFORCE Scan Guage,
SouthBend Stage4
theRTguy is offline   Reply With Quote
Page generated in 0.21063 seconds with 13 queries
