Old 05-04-2008, 04:48 AM   #1 (permalink)
pavendort's Avatar
Member Number: 24487
Question Tune Constantly Changing
I have a map clamp now, and when the temp changes a few degrees it starts leaning out real bad or getting real rich. It is annoying as the temp varies quite a bit each day.
Wondering if I go with a SAFCII, if it will just do the same thing, or if it will compensate for things like ambient temp.
Thanks in advance.
STS, Stage 1, FM WGA, Wideband, DasMopar Mapclamp, Tokico Struts, Eibach ProKit
pavendort is offline   Reply With Quote
Old 05-04-2008, 05:16 AM   #2 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
piggy backs do the same thing as a clamp
Project log pics
Old 05-04-2008, 05:20 AM   #3 (permalink)
pavendort's Avatar
Wow, that sucks then. Thanks. I would have pictured something that expensive doing a little more!
Old 05-04-2008, 06:16 AM   #4 (permalink)
well they just have more adjustment points but same principle
Old 05-04-2008, 01:43 PM   #5 (permalink)
pavendort's Avatar
Is it at least easier to make adjustments on the fly? Now I have to make a run, pull over, pop the hood, adjust, and run again. Usually only 2 runs to get it right. Most days I dont even really hit any boost, but thats because I can only really do it at night without adjusting my tune.
Old 05-04-2008, 01:59 PM   #6 (permalink)
rasp's Avatar
Member Number: 56076
It shouldn't be that bad with a SAFC unless your weather changes drastically. Even running the SAFCII, I only had to make very minor increment changes sitting in the car if the weather got warm or dropped significantly. It should not get out of wack to a point that you actually have to adjust fuel pressure by messing the the regulator.
Old 05-04-2008, 02:02 PM   #7 (permalink)
Jagok1's Avatar
Member Number: 14366
What are you leaving the AFR at with the clamp? Shoot for 11 flat and you shouldn't be having issues.
AGP GT40 -> 317@16psi -> 370@21psi -> Race #'s soon Tuned by NemoFoss
Jagok1 is offline   Reply With Quote
Old 05-05-2008, 03:33 PM   #8 (permalink)
pavendort's Avatar
11.2-11.5 average... Drops to 10 flat towards redline. Sometimes when its hot during the day it will get up to 13.0 and I wont get on it again til its cooler.
I will adjust it down a bit, 11 seems about right. I don't mind making changes, just not twice a day. if the SAFC will hold a bit better I might go that route as I will eventually anyways when I start modding more.
Old 05-06-2008, 09:55 AM   #9 (permalink)
MidLifeCrisis's Avatar
Member Number: 21063
Trader Rating: (23)
With the DTEC you can have 4 different maps stored. Makes for quick changes and you can also leave one map with no fuel at all being pulled.
MidLifeCrisis is offline   Reply With Quote
Old 05-07-2008, 09:31 PM   #10 (permalink)
pavendort's Avatar
That would make a good limp mode... Worth having in case you get shitty gas or something goes wrong.
Old 06-19-2008, 06:58 PM   #11 (permalink)
pavendort's Avatar
So, a guy out here has a SAFCII, and says he never has to change the settings at all based on outside temp... But he seems like a doushcebag, so I am not sure! How hard would it be to change on a weekly basis?
Old 06-19-2008, 07:01 PM   #12 (permalink)
Buy/Sell Moderator
Pizza Boy's Avatar
Member Number: 49788
Trader Rating: (63)
i never had to change my tune on the safc II, once it was dialed in it was done....PERIOD
Pizza Boy is offline   Reply With Quote
Old 06-19-2008, 07:28 PM   #13 (permalink)
pavendort's Avatar
What kind of temperature fluctuations do you get on a daily basis wherever you live? Some weeks it will be a low of 55 and a high of 90. But I drive a lot at night, but have to do a few things during the day too.
If I won't have to change the tune every few days like I do with a clamp, I am definitely going this route. Don't HAVE to tune it on a dyno do you?
Old 06-19-2008, 07:55 PM   #14 (permalink)
2Spools's Avatar
Member Number: 18960
Trader Rating: (17)
You could always go with an SCT Flash. Controls everything the factory PCM can control and will make the car faster and safer. Don't forget hiding boost from the map signal also effects the engine timming.
Stage3 turbo/Stock pcm 11.58@124 JANNETTY RACING SCT TUNED
www.turboaddictionparts.com
2Spools is offline   Reply With Quote
Old 06-19-2008, 08:07 PM   #15 (permalink)
Member Number: 19079
ive only changed the settings a few times.but thats only cuz i live in miami. i have it high to very low 12's.
CANIBUS115 is offline   Reply With Quote
