Old 02-12-2006, 06:05 PM   #1 (permalink)
xtatic's Avatar
Member Number: 23564
Trader Rating: (10)
Default tune to 25 psi?
i finally received my turbo kit and am going to be installing everything this week, this is what im going to be installing:
ACT clutch
RC 750cc Injectors
Autometer 30PSI boost Gauge
Walbro 255lph Fuel Pump
Turbo XS DTEC
Turbo XS High performance BC
Perrin Silver Fuel Rail
AGP fuel return line kit
AGP LHP
AGP t3/t04 50trim Turbo Upgrade
i already have:
Spearco Huge FMIC
JMB Ultimate Intake
JMB UHP w/ HKS SQV
ED 3" Single exit turboback
S1
the place im getting it installed tunes up to 21psi on pump, they will only go past that if i want them to, and they are not responsible for it. my question is how safe would it be to have them tune to 25psi? and after that how safe would it be to run 25 psi as a daily driver. i wont be boosting 25psi everytime i drive though you know, just have it set there.
thnx for the advice
Miami Heat 2006 NBA CHAMPIONS!!!
Stock Stuff For Sale:
All off an 05 less than 10k miles!!!
Fuel Rail
SRT Boost Gauge
Heat Sheilds
Plug Wires
Coolant tank
O2 housing
Crashbar
ALSO HAVE A WOLO AIR HORN!!!!
PM Me
xtatic is offline   Reply With Quote
Old 02-12-2006, 06:12 PM   #2 (permalink)
Member Number: 18709
Too much on pump. 23 is max i would go on 93 pump gas.
way2low01 is offline   Reply With Quote
Old 02-19-2006, 08:56 AM   #3 (permalink)
silver punisher's Avatar
Member Number: 19726
Ditto^^^^^^^^^^^^^^^^
silver punisher is offline   Reply With Quote
Old 02-19-2006, 10:31 AM   #4 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
even on 93 octane and 23psi you will have issues, no more then 21psi for safety. even though you can run 23psi you can't always be certain you will not get a bad tank of gas. I'd rather be safe then push boost and make power for a short while.
Remember 89 motor octane is not that resistant to knock if cylinder pressures are raised beyond its capabilities.
Possibly run 25psi with some 104 sunoco or 109 octane VP.
Old 02-21-2006, 12:47 PM   #5 (permalink)
Member Number: 35604
Thumbs up
Ditto on these guys but I would opt to use one of the DTEC 5 seperate maps and tune a 104 or 109 octane map setting while you have it at your tuner. You will never get a better chance to tune than while it's on a dyno.
If you decide not to tune a seperate map then I would surely go with a MAX PSI of 21 to save those parts you bought.
Simple Guy is offline   Reply With Quote
Old 02-21-2006, 03:10 PM   #6 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (31)
22psi on 94, 25-6ish in 105+
2004NeonSRT4 is offline   Reply With Quote
Old 02-21-2006, 03:40 PM   #7 (permalink)
ladriason's Avatar
Member Number: 23443
same here, 21 on pump, anything else is just better on race gas
My turbo is bigger then yours
ladriason is offline   Reply With Quote
Old 02-25-2006, 11:20 PM   #8 (permalink)
horngrabber's Avatar
Member Number: 32924
Trader Rating: (67)
why? just looking for an explanation... after I tuned, I was spiking 26-27psi and settling down at 23 to redline... all this on 94 Sunoco.
Why is this bad?
ATP GT3071R Kit
- 421whp 403 wtq @ 23psi
- 452whp 423 wtq @ 26psi
Tuned by Aaron @ RealTune - SOLD !!!
2004 Volvo S60R - 6spd
2005 Audi A4 1.8T Avant - Stage 1+
horngrabber is offline   Reply With Quote
Old 02-26-2006, 10:40 AM   #9 (permalink)
Member Number: 4577
Trader Rating: (31)
Why is this bad?
detanation. 94oct can only ignite so much compressed air and fuel due to its octane level. if it can ignite it the extra fuel and air causes detanation. whichs means BOOM. maybe no right away but its a sure thing. general opinion is 22 on pump gas. 24 if u use meth injection with it. and anything more 25+ needs 100ctane plus, the higher the better preferred with out lead.
Old 02-26-2006, 10:59 AM   #10 (permalink)
NIVO88T's Avatar
Member Number: 1109
Why is this bad?
what spring do you have in the wastegate? if the boost is dropping the spring in it is not strong enough.
also, you can run about 22psi on the GT3071R on 94 octane. anymore and you'll pull timing due to knock.
Old 02-26-2006, 11:22 AM   #11 (permalink)
Trader Rating: (67)
Thanks guys... both great answers... I now understand...
Old 02-27-2006, 11:22 AM   #12 (permalink)
Trader Rating: (67)
Nivo... I don't what spring is in there... I'm guessing the stock one... should I be peaking so high with my setup? Is it normal to peak, then settle?
Old 02-28-2006, 01:50 PM   #13 (permalink)
AdictedToPoker's Avatar
Member Number: 11916
Trader Rating: (13)
I have a similar problem with my 50 trim, I have the 18lb spring in and the mbc at the lowest setting, but I still can spike 30 sometimes and settle to 18, and occasionally it will stay at 22ish. I know 22ish should be ok with pump but I put the boost all the way down because I cant stop the spike. When I get home I am going to relook over every thing and check to make sure i didnt install something wrong, but I have yet to figure it out.
AdictedToPoker is offline   Reply With Quote
Old 02-28-2006, 02:21 PM   #14 (permalink)
Member Number: 19937
Trader Rating: (37)
What boost controller do you have?
dubgunit is offline   Reply With Quote
Old 02-28-2006, 03:55 PM   #15 (permalink)
Trader Rating: (67)
Well, I have the same problem..... his is an MBC, I'm using a Blitz SBC id 3... it's one of the best in the world.... the only problem with it, aside from it being a little complicated, is that your set boost is not your real boost... you have to use the gain to get up to it then a limitter to comeback down from the gain...
right now I'm using S1 injectors on my big turbo kit, just for the hell of it.... and the boost is set at 16.5.... my gain is at 4 and my limitter is at 2.... I spike 17psi and settle at 16.6... so I'm learning how to use it properly now...
