Old 09-23-2009, 02:44 AM   #1 (permalink)
Member Number: 70302
Default tip sensor
hey guys i got a question i was wondering if i am able to hook a stage 2/3 tip and a 3 bar map using a stage 1 ecu. what would happen if i do so. but mostly wan to know if i can just hook up a 2/3 tip.
shelbydodge155 is offline   Reply With Quote
Old 09-23-2009, 12:57 PM   #2 (permalink)
duster360's Avatar
Member Number: 45182
If you hooked up a S2/S3 TIP your Barometric pressure reading would be all jacked up. Since the PCM uses Preassure Ratio (MAP/BARO) as a key parameter in its fuel calcs and boost control, I'm guessing goofy things would go on.
Page generated in 0.11788 seconds with 13 queries
