Old 01-28-2005, 10:09 AM   #1 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
Default Timing-Advance, Retard
How does affect the performance? It seems to be a big issue when more boost is added. Can someone explain the relationship it has. Thanks.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 01-28-2005, 11:13 AM   #2 (permalink)
Member Number: 5634
More timming = more power
More timming is more prone to detonate,ping or knock
More boost = Is also more prone to detonate
Cheap gas (low octane) will cause you to detonate and the knock sencer will pull (retard) timming.
Timming is "when" the spark ignites the A/F mixture.
All you want to do is hold good timming with out detonation. If you are worried about it run better gas.
I bought it because it's american made
mohillmopar is offline   Reply With Quote
Old 01-28-2005, 11:25 AM   #3 (permalink)
Trader Rating: (37)
Is it a good idea to adjust the timing yourself or should you just run the recommended gas, 91 or higher, and let the ECU adjust accordingly?
Old 01-28-2005, 11:33 AM   #4 (permalink)
Trader Rating: (37)
When you refer to more timing you are saying advance the timing - when it is said "pulling" timing is that refering to retarding the timing?
Old 01-28-2005, 12:36 PM   #5 (permalink)
91CavGT's Avatar
Member Number: 2012
The factory computer adjusts timing as it sees fit. There is no adjustment that you or I can make to it.
If the factory computer sees knock(knock does not have to be audible) then the computer will retard the timing. This is comonly refered to as "pulling timing".
If you are stok, 93 octane gas will give you the best timing curve. If you're car is modified, then higher octane gas will give you more ignition advance IF there is knock. If there is no knock then running higher octane gas will actually decrease the cars performance.
1991 Cavalier Station Wagon - 3.2L cammed and turbocharged V6
Fastest privately owned/driven SRT-4 at NPR's road course during the 2004 SRT4 National Meet
Drive it like you stole it.
Yes, I'm a water injection whore!!
91CavGT is offline   Reply With Quote
Old 01-28-2005, 02:56 PM   #6 (permalink)
Member Number: 5634
Thats why it is good to look for power in NON-OCTANE limited modifications like TBs,Intake Manifolds,Exhaust,CAMs. Even though they could be traced back to needing more octane.
Page generated in 0.16820 seconds with 13 queries
