Old 10-03-2008, 11:53 AM   #1 (permalink)
supermancjl's Avatar
Member Number: 57738
Default Timing Advance Q's
I'm fairly new to the srt and turbo cars in general. I bought my car the way it is and I am still learning. My question is, are my timing readings too high? I am reading timing, knock etc. with the Aeroforce Scangauge. At idle it displays 5-8 on timing advance, then as I cruise or pull a bit, it will go up to the 45-48 range. My mods are listed below
AGP 50 trim
Turbonetics Evolution WG
Mopar/Borla exhaust
Stage 1
750cc Injectors
AEM CAI
255lb walboro pump
DTEC FC
"full race" FMIC
TXS Manual HP BC
2004 Dodge Neon SRT-4
supermancjl is offline   Reply With Quote
Old 10-04-2008, 01:35 AM   #2 (permalink)
bump ttt
Old 10-04-2008, 02:48 AM   #3 (permalink)
mebcop's Avatar
Member Number: 42028
what does it read at full boost at like 5000rpms?
AGP return line, AEM SRI, AEM UEGO Wideband, VRS 3 inch Exhaust, Maxxfab 3" DP w/o cat, DW 750's, MPx FMIC , 50 Trim AGP, HKS SSQ BOV, Turbonetics evolution wastgate, OBX IC pipes, Labonte Motorsports W/M kit, SBC Stage 5 clutch, Perrin MBC, Maddog 80% STS, bottleneck fix, walbro 255, Bwoody MM, AEM 3.5bar Map Sensor, Rage-Tek Map Sensor Adapter.EMS INSTALLED: 433 WTQ ON A MUSTANG DYNO UNCORRECTED WTB:TRACTION HAHAHA
mebcop is online now   Reply With Quote
Old 10-04-2008, 01:56 PM   #4 (permalink)
it reads about 48-49
Old 10-04-2008, 06:42 PM   #5 (permalink)
mebcop's Avatar
WHAT!!! almost 50' of timing at full boost!!!!!!! Not good. What's your knock retard???
Old 10-04-2008, 09:20 PM   #6 (permalink)
my knock is 8-9 counts at WOT. I figured it was high because at cruise its in the 40's also. HELP!!!! lol What things should I look at first?
Old 10-04-2008, 11:25 PM   #7 (permalink)
mebcop's Avatar
Cruising that high is just fine.... it's when the engine is under load that it's very dangerous. I am running 27' of timing advance with a 50 trim at 25psi WITH WATER METH. I've seen knock at 29' of timing with that setup..... I couldn't imagine 50' of timing!!!!!!!!! The reason you're running so much timing is because you're hiding too much boost from your pcm. It thinks your only running like say 5psi of boost when you're actually running a lot more than that. That is why I ended up going with EMS. Tuning with the piggy back, you reach a point where you are only allowed to show the pcm say 15psi before it pulls timing, but you want to run say 23, so hiding 8 psi of boost causes WAYYYYY too much timing. I guess with the AFC, the trick is to make a ton of power without having to hide that much boost..... can get tricky
Old 10-05-2008, 05:01 AM   #8 (permalink)
Member Number: 30696
just get your Fuel pressure so that at redline, you are pulling very little fuel out..
from 5k to 5.5 im only pulling 6% out, then at 5.5 to 6.2 im only pulling 3 - 1 % out. helps the timing not get to ramped up :-D
amdguy is online now   Reply With Quote
Old 10-05-2008, 06:03 AM   #9 (permalink)
^thanks guys, any more advice from anyone???
Old 10-06-2008, 10:54 AM   #10 (permalink)
bump.
Old 10-06-2008, 11:02 AM   #11 (permalink)
Member Number: 64760
Trader Rating: (18)
there's no way you have 50* of timing at WOT.
91PumpKing. is offline   Reply With Quote
Old 10-06-2008, 11:08 AM   #12 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
^ x2 if you did......your engine would be "knock knock knockin on heavens dooooor" literally
Old 10-06-2008, 11:16 AM   #13 (permalink)
Trader Rating: (18)
^^^ nice song selection.
Old 10-06-2008, 02:24 PM   #14 (permalink)
from what i remember, it is, i'll go do a pull in a bit and let you know. as for knock, it is knocking that is my problem also. This is being read from the aeroforce scangauge
Old 10-06-2008, 09:00 PM   #15 (permalink)
I stand corrected I got my numbers mixed up, I was reading 50* of timing when I was cruising at about 80-85 mph on the highway, is that normal? I did a couple of quick pulls and at WOT it was in the 30's, again is that too high? I read about 6-9 counts of knock at WOT
Page generated in 0.22292 seconds with 13 queries
