Old 06-27-2004, 06:43 PM   #1 (permalink)
Member Number: 6220
Default tach adapter part# 8912
where do the wires from the tack adapter go on the car. Do they go to the pcm or to the coil wires where should we conect the rpm wire form the apex to the msd or to the pcm if so witch wires reseving rpm singnol for knock please help asap not setting
crazysrt4 is offline   Reply With Quote
Old 06-27-2004, 06:51 PM   #2 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
whoa...I saw 1 sentence in there....can't make out the rest
you can connect the tach adapter to the coil harness.
Old 06-27-2004, 06:58 PM   #3 (permalink)
Member Number: 6220
brown-white wire dose it go to the coil or to the pcm green -red dose it go to the coil or pcm brown -green wire witch to conect to the color to contect and to coil or pcm white wire where dose it go and green wire where dose it go the derections from msd suck
Old 06-27-2004, 07:26 PM   #4 (permalink)
electricblu's Avatar
Member Number: 8822
I thought the part# for the tach adapter was 8913?
That is what I use in my car...and it works.
The color wires you are mentioning do not match what mine has, so I can't help you..
I think you bought the wrong one.
2004 Competition Orange Mustang Cobra Coupe
2004 Dodge SRT-4 (450whp)- SOLD
2004 Dodge Hemi Durango Limited
AIM = getownedtoday
electricblu is offline   Reply With Quote
Old 06-27-2004, 07:41 PM   #5 (permalink)
Member Number: 6220
i know turbo neon store sent me 8912 i dont know what to do
Old 06-27-2004, 09:20 PM   #6 (permalink)
Member Number: 8152
Hmmmm, I have PN 8913 from the same guys....
Objects in mirror are losing....
fatged is offline   Reply With Quote
Old 06-27-2004, 09:50 PM   #7 (permalink)
SRToc Member
Member Number: 2005
Trader Rating: (20)
<--- MSD 8913 too.
Greg 04-SRT4
Greg_04-SRT4 is offline   Reply With Quote
Old 06-27-2004, 10:12 PM   #8 (permalink)
Exhaust Depot's Avatar
Member Number: 143
Trader Rating: (98)
Quote: Originally Posted by Greg_04-SRT4
<--- MSD 8913 too.
Cut greenwire with orange stripe on the coil. This is the VCC for the coil. Attach the red with green stripe TOWARDS the COIL. Attach the solid red wire towards the POWER DISTRIBUTION.
THe black is ground, I like to attach it tot he battery cable. THe grey is your tach signal.
You can tie wrap the unit to the hoses and vacuum lines on the side of the battery tray.
If you dont have a soldering iron, then you should not be purchasing this item.
Yo!
Exhaust Depot is offline   Reply With Quote
Old 06-27-2004, 10:46 PM   #9 (permalink)
NIVO88T's Avatar
Member Number: 1109
Yo!
Hey hec. I added this to the SAFC thread in the first post.
Old 07-10-2004, 03:29 PM   #10 (permalink)
Member Number: 6713
does the 8912 tach adapter not work for are cars?
I stole the line but its how I do Things. "If it aint broke, fix it till it is."
Rickelus4 is offline   Reply With Quote
Old 07-10-2004, 03:34 PM   #11 (permalink)
NIVO88T's Avatar
Member Number: 1109
you want to use the 8913 MSD. for distributorless engines.
Old 04-17-2005, 03:33 PM   #12 (permalink)
Member Number: 9712
I got the 8912, modern performance told me 8912. I am getting the 8913, If anyone knows what the 8912 works on I will sell it for cheap! like 20 bucks, you just gotta come to bellingham
meek61480 is offline   Reply With Quote
Old 04-20-2005, 01:09 AM   #13 (permalink)
MrCleanSRt4's Avatar
Member Number: 5785
Trader Rating: (29)
Default 8912,8913
I think there is some con fusion here
MSD #8912....this adapter allows the use of an aftermarket msd ignition..#62112....to work properly with our waste spark, distributorless ignition coils.
MSD#8913 .....tach adaptor only.....this is used only if you need a clean readable tach signal...for a shift light...tach...SAFC-2...emanage ...etc
MrCleanSRt4 is offline   Reply With Quote
Old 06-19-2005, 10:55 PM   #14 (permalink)
jfk
jfk's Avatar
Member Number: 25544
Maybe I didn't read the directions real clear (like for three hours), but I ordered the 8912 and tried wiring in my programable MSD DIS-2 to my '05 SRT-4 and no-way would it allow the car to fire. Even with the by-pass plug in it. I'm gonna try again tomorrow without the adapter and see if it will fire up. It was much easier on the chevy. Same waste spark, just dual coils with inline coil modules. If anyone else has successfully hooked up an MSD ignition, please post on here how you got it to work! Thanks!
P.S.
Don't say you just wired in something.....please explain. Thanks again!
jfk is offline   Reply With Quote
Old 06-19-2005, 11:20 PM   #15 (permalink)
Member Number: 9751
mine worked, do you have the wiring sheet that came with the dis-2 that shows the correct way to hook it up.
New custom s372r setup:
750hp, 560tq...26-27psi not spray
through dcr auto trans..
****Second street Srt-4 in the 9's 9.95@143****
old setup:
742hp, 650tq...35psi&90shot of spray from a 37r through a dcr auto trans..
**worlds Fastest Dot tire srt-4**
10.51@144
kevinwarren240 is offline   Reply With Quote
Page generated in 0.21727 seconds with 14 queries
