Old 07-30-2006, 06:15 PM   #1 (permalink)
Ant
Ant's Avatar
Member Number: 2834
Default super rich need some help
mods in sig
i am pulling 17% from 2K to 4.5K in the Airflow map @ 100%
Boost is hitting 18 psi and finishing at 20 psi at redline.
a/f is in the 9s from 3K till 5K were it leans out gradually to 11.1-11.5
my fuel pressure is 41psi vac line off 34-35 vac line on
Car feels like ass till 5K when it leans out. Pulls hard right near redline.
I have clamped as low as 4.10, but the a/f is still in the 9s.
I have upped the clamp to 4.64 from 5K to 6.5K.
PLEASE HELP
AGP 50 Trim
Stage 1 AGP SCT FLASHED
NGK plugs gapped .35
HP Racing/ Magnaflow 3" turboback
ED Hard Pipes w/Greddy Type S BOV
Accel 300+ RED Spark wires
Spearco BIG FMIC
EMANAGE / E01 / LM1 / FPR / Deatchwerks 750cc
injen intake
180 themo
Clutchmasters Stage 3
Bwoody Traction Bars
PTp Check valve
Aerforce/AAronneon Interceptor Scan Gauge
Ant is offline   Reply With Quote
Old 07-30-2006, 07:25 PM   #2 (permalink)
Ant
Ant's Avatar
Member Number: 2834
here is a the e01 screen
boost is in bold
10.2 reading is the A/F, the e01 will not read any lower, my lm-1 reads 9s
my ad injection map is 0 everywhere
what else should i do to lean out the midrange?
Old 07-31-2006, 09:41 AM   #3 (permalink)
Ant
Ant's Avatar
Member Number: 2834
any suggesttions?
lower fuel pressure more?
help
Old 07-31-2006, 12:00 PM   #4 (permalink)
Novertrunion05's Avatar
Member Number: 36646
Maybe try fooling around with your map clamp a little bit.
Novertrunion05 is offline   Reply With Quote
Old 07-31-2006, 12:06 PM   #5 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
Quote: Originally Posted by Ant
mods in sig
Sounds like a boost leak problem is the start here . . .
The increase in boost pressure towards redline would be a cause for your A/F to go up. Boost should be spiking then falling towards redline. This will allow you to start at a lean condition and drop to rich. Mine hits 12.0 then falls to 11.8 towards redline.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 07-31-2006, 04:10 PM   #6 (permalink)
Ant
Ant's Avatar
Member Number: 2834
mods in sig
ok, i was trying to use the rpm offset but not working because i have not hooked up the brown wire from the e01 to the tach driver. gonna do that to get consistent boost.
I have lowered the pressure more and now it is in the mid 10s when boost comes on and i added fuel after 5K in the aif flow map to keep it from going lean. and 9s at redline, will update with more info as i keep tuning it.
Old 07-31-2006, 04:24 PM   #7 (permalink)
Trader Rating: (37)
Sorry I really can't help you too much with tuning the E01, but I can help you with boost and A/F.
Keep updating though . . .
Old 07-31-2006, 04:46 PM   #8 (permalink)
vegasDSM's Avatar
Member Number: 726
might want to geet in touch with hector from exhaust depot... he swears by the Eo1 system...
F this forum and it's bullshit ads......ekool has jumped the shark
www.myspace.com/vegasdsmr<--vids....................
http://www.WebPeople.us
http://www.WebPeopleVideos.com
vegasDSM is offline   Reply With Quote
Old 07-31-2006, 05:58 PM   #9 (permalink)
Ant
Ant's Avatar
Member Number: 2834
yea...he really doesn't mess with this stuff anymore
Page generated in 0.21152 seconds with 13 queries
