Old 10-07-2006, 07:51 AM   #1 (permalink)
agamemnon5150's Avatar
Member Number: 30326
Trader Rating: (27)
Default stuck AEM wideband
so when I first put in my wideband it worked just fine....now sor some reason it seems to be stuck displaying a certain AFR for some reason. Most the time it just says 14.8 and will stay like that the whole time I'm driving....but somtimes it will get stuck at 15 or 16 as well. Not fluxuating at all, just displaying that numer the whole time.
Maybe my O2 sensor went bad? Or maybe my wires got bent/worn or someting? Its all still connected and nothing look out of the norm.
anyony have any idea what it might be?
,Thanks
SRT's OVERSEAS
agamemnon5150 is offline   Reply With Quote
Old 10-07-2006, 10:02 AM   #2 (permalink)
Member Number: 33625
I turned mine on with the sensor disconnected and it will sit at 14.7 and never move. Check for burned or worn wires like you said, or your O2 sensor might be bad. If you have a friend with a UEGO try switching sensors with him and see what happens. Good luck with it!
SiGuyUWP is offline   Reply With Quote
Old 10-07-2006, 11:24 AM   #3 (permalink)
Trader Rating: (27)
yea but sometimes it changes to 15 or 16....and everythings connected.....hummm
Old 10-09-2006, 01:41 PM   #4 (permalink)
nme
nme's Avatar
Member Number: 42393
check the wireing. when i had my sensor unhooked it read 14.7. Then the brown wire going into the wideband got loose and it made it read 14.7 Check the wires in the connector.
nme is offline   Reply With Quote
Old 10-10-2006, 11:38 AM   #5 (permalink)
Trader Rating: (27)
thanks....will do
I'm thinking its a bad O2 sensor....because sometimes it will change to a leaner number...if it was the wiring, it wouldn't change at all would it?
Old 10-10-2006, 03:02 PM   #6 (permalink)
nme
nme's Avatar
mine changed like you described when it was the wire.
Old 10-12-2006, 07:28 AM   #7 (permalink)
Trader Rating: (27)
thanks I'll make sure I try that 1st then....befor I go spend the money for a new sensor
Page generated in 0.17753 seconds with 13 queries
