Please stop posting misinformation mr Fury.
4drhtrd,
It is a narrowband. It rides on a preset DC level. Around 3V if I recall correctly(the one in the 02 housing), so with a MM you will see ~3-4V swings.
For the sake of argument you can confirm this with a Volt meter. The wire/signal could be found in the service manual.
Proper OBDII logging SW will display the output on a 0-1V Scale.
someone is watching me
