Old 09-25-2009, 10:05 AM   #1 (permalink)
Member Number: 31038
Trader Rating: (50)
Stage 3 w/ return style setup?
Mopar Stage 3 w/toys. Walbro 255lph and fuel pump rewire.
My car has been running rich lately specially during spool up. (LAG) and my buddy said I should switch over to a return style setup and that would solve that problem since I could adjust the FPR at the rail.
Has anyone done this and netted good results?
Could I keep it on PCM controlled boost?
Would I need a tuning device to optimize this?
Thanks for any input. I remember seeing a thread aobut this ages ago but I could not find it.
raul-01 is offline   Reply With Quote
Old 09-27-2009, 12:14 PM   #2 (permalink)
Member Number: 73205
to many replies , yikes.
inis is offline   Reply With Quote
Old 09-27-2009, 12:20 PM   #3 (permalink)
Member Number: 36585
disconnect the #3 fuel injector, that should lean the car out...
just-a-neon is offline   Reply With Quote
Old 09-27-2009, 12:27 PM   #4 (permalink)
Figs's Avatar
Member Number: 52595
Trader Rating: (70)
You can but I've yet to have any experience with doing so. Its an alternative to not running the S3 fuel setup.
A friend of mine OrionR12 on here is running a returnline setup with his S3 w/toys kit. Its on PCM controlled boost and uses all the toys features. He adjusted the fuel via the returnline, other then that no other tuning device involved. AFR's on his car are within a mid 11 to 11.8 range I believe.
Figs is offline   Reply With Quote
Old 09-27-2009, 02:33 PM   #5 (permalink)
Trader Rating: (50)
That would be PERFECT! ^
Problem I get is upon spoolup I am low to mid 10's then it gets leaner towards redline, like mid 11's... I always thought it supposed to be lean and then start going rich towards redline.
Old 09-28-2009, 12:37 PM   #6 (permalink)
A fpr with 1:1 raise like what I'm running, rich and just about everyone else is.. would help with your running into the 11's towards redline.
Has anyone datalogged fuel pressure throughout the powerband, with a s3 set up?
If it keeps the same pressure throughout the powerband OR raises at a 1:1 rate with boost...this will be an extremely easy upgrade.
If no one has stephen, I say we put a gauge on the end of your fuel rail and moniter it during your next dyno day. This would also tell you if the fuel pump is getting maxed out or not.
Old 10-01-2009, 03:17 PM   #7 (permalink)
Member Number: 25857
i'm stage 3 and my fuel pressure at wot holds at 68psi to redline. i also run rich at first during woot starting out at 3000rpm then it gets leaner towards redline.
H22-T is offline   Reply With Quote
Old 10-05-2009, 12:08 PM   #8 (permalink)
Trader Rating: (50)
How do you know you are running 68 psi at redline? You have a fuel pressure gauge hooked up?
So far no one in this thread has a Stage 3 car with a return line setup. Just trying to get feedback from people that have it.
Old 10-05-2009, 12:46 PM   #9 (permalink)
Old 10-05-2009, 12:49 PM   #10 (permalink)
Member Number: 52407
You could have gotten an isolator kit and then run the mechanical fuel pressure gauge in cabin. Or you could have gotten a fuel pressure sending unit and run the 0-5v signal to your scan gauge and recorded the fuel pressure reading.
7055 is offline   Reply With Quote
Old 10-06-2009, 12:07 AM   #11 (permalink)
Trader Rating: (50)
Old 10-06-2009, 08:28 AM   #12 (permalink)
duster360's Avatar
Member Number: 45182
Its taped on for a 10-15minute ride,guys. A quick trip around the block, a few WOT runs and you're done.
Yes it looks a little goofy but its quicker, cheaper and easier than buying expensive in cabin fp gauge or worse blindly throwing parts at it. Too many newbs rather ask someone's opinion when they think they have fuel system issues rather than just test it. If fp is stable, there's no issues. If it drops at WOT, somethings up.
I monitor fp only when there might be a fuel issue--thats been only twice in over a year. Thats not enough to spend $80-$150 on a in-cabin fp gauge.
A good fuel pressure gauge is a priority to have in anyone's tool box. Although I've only used my gauge 2 time in a year on my SRT, I must have used it a dozen times or more on other vehicals.
Old 10-06-2009, 10:45 AM   #13 (permalink)
Trader Rating: (50)
I was just laughing because it looked funny with all the duct tape and all. I guess I will try it out. It just hooks up to the schrader valve on the right side of the fuel rail?
Page generated in 0.17816 seconds with 13 queries
