07-06-2008, 02:56 PM
#1 (permalink )
Member Number: 55819
stage 1 ecu with stage 2 wga and injectors
is it safe to run with a s1 ecu and s2 injectors and s2 wga? just curious due to s2 ecu throwing a lot of codes and had s1 ecu laying around...
S2, 60mm Throttle Body with Manifold adapter by LFS, 3in CAI, GReddy Catch Can , Upper Engine Torque Arm, Prothane Mounts, MSD Ignition, 180F thermostat, Turbonetics Pipe w/ Type S, AGP Blow Off Valve Block Off Plate, 3" Exhaust by Borla, 3" Downpipe, Mopar Performance Short Shifter, Eibach Sportline, Strut Tower Bar & Rear Strut Bar, Mopar Tailights, GReddy Turbo Timer, SRT air/fuel gauge and volt gauge, Fiber Images CFH, CBD Eyelids
07-06-2008, 07:20 PM
#2 (permalink )
Member Number: 55729
It will probably run a little rich because the S1 PCM is calibrated for the smaller injectors. When compared to an stock PCM, S2 PCM's don't throw codes...
Stage 2 w/o toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP no-cat, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, 180 thermo, RFR check valve, Prothane race MM inserts, Autometer 30/30, SCT Tuner, Tein H-techs, Proparts dual-gauge pillar, Fuel pump re-wire.
07-06-2008, 07:33 PM
#3 (permalink )
Member Number: 11361
yea its fine.
i run s2 injectors, w/s0 ecu -- even made it through inspectoin
Quote: Originally Posted by
AdamGillesPIE
is it safe to run with a s1 ecu and s2 injectors and s2 wga? just curious due to s2 ecu throwing a lot of codes had s1 ecu laying around...
PCM=S0
injectors=S2($160)
S3R DCR manifold ($500) w/evo8 turbo (ebay $150)
MAP clamp/EBC (my own design-- parts $10)
Spring Mod (my design $5)
24x12x3 FMIC (generic $140 ebay special) - ugh
Filled Motor Mounts, Flexane $35
Valve cover, red -- Rustolium High Temp $5
ODB2 setup (scantool.net (ebay $70), DigiMoto software)
DataLogger DataQA, $25
Wideband LC1 (ebay $165)
wheels=16x8.5 w/245/45/16
needswing v5 <forums $60>
Next
3" O2 ,WI_DIY
07-06-2008, 08:18 PM
#4 (permalink )
well after i posted that i got to looking around and read that another person was having the same problem and it was due to the MSD coil so i removed my MSD coil and no codes came on and the car ran really strong
Linear Mode
» Site Navigation
> Other Vehicles
