Old 07-12-2008, 01:54 PM   #1 (permalink)
04BlueSkittle's Avatar
Member Number: 52567
Default so i port and polished my throttle body and....
my afrs dropped from 11.5 at wot to 10.5 at wot in third gear. i tuned it with my safc 2 before i port and polished it and i locked the screen so no one could change anything. anyone know why it dropped so durastically.
Painted stockers , msd 8.5 wires, champion spark plugs .36 gap, MPx 3in tbe, aem wideband, prothane MM's, mopar bov, AGP wastgate hold 18/15, MPX 3in o2 housing, PTP Ported Exhaust Manifold, booger bushings,180 degree thermo, SAFC II w/ msd tach, ptp fan switch mod,NO BOOST LEAKS!!!!
04BlueSkittle is offline   Reply With Quote
Old 07-12-2008, 02:02 PM   #2 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (49)
You sure it didn't go from 10.5 to 11.5?
ASE Certified Automotive Technician
Old 07-12-2008, 02:22 PM   #3 (permalink)
dude come on^^^^^^. i know how to read a afr gauge. i am gonna check my safc 2 and see if the settings got set back to default. be right back.
Old 07-12-2008, 04:34 PM   #4 (permalink)
Member Number: 25021
He was just confirming. You know how that goes sometimes, people do write shit backwards. I do it too
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 07-14-2008, 08:46 PM   #5 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
Porting and polishing can actually diminish performance if done improperly. I'm not saying you did it wrong, but if you created more turbulance or a poor flow path(what ever you want to call it), less air get's in the engine. Borrow a friends TB and see if your a/f changes back.
sour kraut is offline   Reply With Quote
Old 07-14-2008, 10:07 PM   #6 (permalink)
yeah i know that part i polished the stuff out of that throttle body. i know if i ported it wrong it should flow wrong but i should have the same afr right. and my safc 2 is still where i had it. i amm gonna due some more pulls. also when i start up my car in the morning it takes like 3 seconds or 4 to start. i think its my fuel filter i dont think its been changed since stock. i have had the car for 20,000 miles. so i think that would be cause the fuel to richen. shit gettin clogged up in the filter
Old 07-15-2008, 02:24 PM   #7 (permalink)
sour kraut's Avatar
a clogged filter would mean less fuel which means a leaner mixture. Do you have a return line on the car? Start the car and let it run for awhile. Look at what your fuel pressure is. When you shut it off, if it drops right away, your regulator is shot. If it's stock, the regulator is built into the filter. Good luck.
Page generated in 0.16255 seconds with 11 queries
