No. The DRB tool is the only tool available to do that. The flasher does nothing more than flash and check/clear engine codes. Aside from writing a map to the ECU, it does not have the capability of changing any of the ECU's parameters on-the-fly, nor does any type of tuning software we have have the ability to allow the cross-usage of different ECU's. Your best bet would be to find a dealer who will flash an '04 ECU with your VIN to allow you to use it, or you'll have to buy a staged computer for flash purposes. For the latter at least you know you can always revert back to a staged computer in case you aren't fond of the SCT tune(s).
