Quote: Originally Posted by
BoostinByeU
14.9 15.0 at idle and 11.8-12.1 on wot. not to lean up top 11.8near redline pull fuel slowly and a couple of 3rd gear runs should do the trick.
a scan gauge wouldnt be bad either so you can see your timming and knock.. wideband, scangauge. then start tunning your car set your boost, then adjust fuel to stated a/f ratio, then adjust timming if needed to get rid of knock if you have any at all.
