Old 07-01-2008, 12:47 PM   #1 (permalink)
Member Number: 56301
Default My safc II is missing wiring harness HELP
HEY GUYS I HAVE BOUGHT THIS A LONG TIME AGO off ebay AND i did not know this unit needed harness. Well now i have a sacf II unit without wiring harness. What can i do? Is it still workable? Can i get the harness somewhere else if so where? i will post pict in just a min
upadate here are the pictures guys...
thats all i came with it
EvilGoat is offline   Reply With Quote
Old 07-01-2008, 01:02 PM   #2 (permalink)
my_little_srt's Avatar
Member Number: 41179
What did you think it was battery powered?!?!?!?
Look for the manufacture and model on the unit..Call said manufacture. Let them know your model number. Then order the harness and all necessary parts........
my_little_srt is online now   Reply With Quote
Old 07-01-2008, 01:03 PM   #3 (permalink)
it did not come with any manuals at all, i dont even know what number to dial
Old 07-01-2008, 01:15 PM   #4 (permalink)
JdM2UsDm's Avatar
Member Number: 47984
Trader Rating: (18)
i think i may have one in the house from when they broke into my old car n took my afc .... if i do i'll let u know tonight...
New project
2003 Lexus IS300 pearl white
5-speed manual W/ LSD
Boost coming soon!!!
2005 Stone White (traded )
266WHP 320TQ
Stock turbo 19psi spike 16psi redline S1, 650cc, afc neo, cai, 3" tbe, slipping clutch everything else stock.
JdM2UsDm is offline   Reply With Quote
Old 07-01-2008, 01:15 PM   #5 (permalink)
It should say the make and model some where on the unit itself.......
Old 07-01-2008, 03:57 PM   #6 (permalink)
i called apexi they said that i will have to buy a harness from them and somehow solder the wires together. does this make sense? is there any other way to do this?
Old 07-02-2008, 12:10 AM   #7 (permalink)
Dude. I hate to say it, but it looks like your screwed...Looks like the unit was stolen, by the way the lines are cut. I would just buy a whole new one......
Old 07-03-2008, 08:42 AM   #8 (permalink)
Member Number: 51439
Trader Rating: (12)
Correct me if im wrong, but that is a SAFC, not an SAFC II... Also, im not sure about on the SAFC, but on the SAFC II you do not need a wiring harness... Just extend the lines with regular wire...
PTP SSTv2, Ported Exhaust Manifold, MaxxFabb 3" O2 Housing, Needswings v5 w/cutout, Mopar Exhaust, BFMIC, Bwoody Motor/Trans Mounts, 55mm Ported Throttle Body, Injen Cold Air Intake, MSD Wires, HKS SSQ BOV, LC-1 Wideband, DTEC FCBC, Stage 2 Injectors, Walbro 255, PTP FPR Mod, AGP Hardpipes, AGP Wastegate, Bwoody Catch Can, Check Valve, Mopar STS w/boogers, Coolingmist Meth/Water Injection, Fuel Pump Re-Wire
low0r is offline   Reply With Quote
Old 07-09-2008, 09:02 AM   #9 (permalink)
so does anyone knows how to fix this shit , im so pissed off cuz it seems that i got scammed
Old 07-10-2008, 02:18 PM   #10 (permalink)
Member Number: 40273
Trader Rating: (21)
They dont make a wiring harness for our cars. Those safc's need to be wired/soldered into the cars wiring near the pcm.
Get some wire and a soldering gun and extend the wires about 8 feet. Make sure you label the new wires with the same coloring code. Then go to the How To section and search for the SAFC thread and install it.
By the way, that thing was surely stolen, and I'm sure before they cut it, they yanked on it as hard as possible to get more slack, fucking up the connections inside.
Good luck
S3Rh
Missing 04 Eblue as of 7/11/08.
98turboteg is offline   Reply With Quote
Old 07-13-2008, 09:13 PM   #11 (permalink)
OH5SRT4's Avatar
Member Number: 21866
Trader Rating: (19)
Yeah that is definately an original SAFC. The 2's have a dial, not buttons.
2005 Black SRT-4
Mods: 3" O2 housing/Maxxfab DP, Mopar Catback, CCA FMIC, AGP CAI, BWoody Tranny/Motor Mounts, Hotchkis Springs, HKS BOV, Kinetic WGA, Mopar STS, AEM Wideband, PTP Check Valve, JMB Catch Can, 180 T-Stat, MSD Wires, CF OEM Hood, Black Housing Headlights
XBL Gamertag: The Hammerman37
OH5SRT4 is offline   Reply With Quote
Old 07-13-2008, 09:33 PM   #12 (permalink)
^^^ Does the original safc does the job just like the others ?
Old 07-14-2008, 10:05 PM   #13 (permalink)
OH5SRT4's Avatar
Trader Rating: (19)
Yeah it'll work. If I'm not mistaken though it only stores 1 map whereas the safc2 stores 2? Someone correct me if I'm wrong there. As far as tunable points I believe they both have the same.
Old 07-15-2008, 08:33 AM   #14 (permalink)
^^^^ ohhh man, i wanted two maps damn
Old 07-15-2008, 01:35 PM   #15 (permalink)
OH5SRT4's Avatar
Trader Rating: (19)
Well like I said I think that's really the only difference. I'm not 100% sure though that it only does hold 1. Hopefully someone else will chime in for you.
Page generated in 0.30868 seconds with 11 queries
