I just got back from street tuning my car and l was trying to get my a/f ratios perfect. l have a 50 trim kit on STOCK fuel system and everytime l turned the boost up, the a/f ratio would go down lower and lower.
Here's a breakdown of my boost against the a/f ratios. All the pulls were in 3rd gear.
Also, when l hit full boost, it holds and then starts falling down like the stock turbo. I thought big turbos didn't drop like that. Could it be a boostleak?
Mods
50 trim .63 AR
TurboXS MBC
Safc II w/ tach adapter
NGK Wideband
That's the crazy thing about it, l'm on stock 05 injectors. I talked to fullybuiltchris and he was stumped by this too. I'm sure there's a reasonable explaination for it.
Do it right and get the bigger injectors all the supporting mods. Do you have a internal or external wga? externals dont spike from what ive learned from a friend that had a dsm. and internals do.
stage 0, stage 1 injectors, agp wga, needswings e/cutout, mopar noise valve, k&n look alike drop in, hood mod, das mopar map clamp, aem uego wideband, greddy profec b ver 2, tokico illumina, tein s tech
13.8 stock tires & needswings e/cutout
I know what l need to do it right, but l just don't have the funds right now to get the bigger injectors, so l'm tuning what l have. I have an external wastegate like all other 50 trims for our cars do and l thought they didn't spike either.
The a/f ratios are not suppose to be going down, they should be going up. 13-14 psi should be maxing out my stock fuel system. I tested the wideband and it's working properly, l'm pretty stump on this problem.
first guess, pulling timing? pinging?
second guess, map clamp - try .1v lower (something like 4.1v)
Timing! That's what l was thinking. The car must be pulling timing and adding more fuel to compensate for the higher boost, that's why it keeps getting richer as the boost rises. Why does the boost drop after l hit full boost?
I was just out testing my S2 WGA and I had similiar results....
When I would get on it in DAB 2-3 i would spike 17PSi with a AFR of about 10.0
In DAB 0-1 I would get on it and it would spike at like 12psi and run like crap throwing a AFR of 12.1
Shit is pissing me off... seems totally back asswards
With a big turbo kit and using the LM-1 tuning in 3rd gear I can boost 18 psi safely around 11:7 AFR. I now Have my cooling mist single stage running now too. But figured I will wait to up the boost too much still until I get the rest of my fuel set up in. I also have an 05. BTW you have a boost leak. While doing my w/i install found a 1" cut in my lower hump coupler. Now that was fixed I can hold 18-19 psi all day and still in safe AFR with just MOPAR stage 2 injectors. Hope that helps
[IMG][/IMG]
Best 1/8th: 8.205 @ 84.95 Best 1/8th MPH: 86.37 <<< These are so 2005 I need new numbers
