Old 12-09-2005, 12:54 PM   #1 (permalink)
TrevSRT's Avatar
Member Number: 33810
Default Mapclamp tuning...
I just installed my mapclamp on my car at the pre-setted settings from dasmopar....
when I do a 3rd gear pull soon as I go wot it hits 11.0 and rises to about 11.8 a/fr near redline...
4th gear hits 10.8 at the bottom of it, and towards redline it constantly rises, and at the end of 4th I have: 11.9 a/fr
should I leave it like this (this is how it came with my mods below is my a/fr, the mapclamp is unadjusted from being received)
I am using the agp wga to spike 18, and fall to 15 at redline....any help is appreciated, thanks!
TrevSRT is offline   Reply With Quote
Old 12-09-2005, 01:12 PM   #2 (permalink)
Battlefresh's Avatar
Member Number: 34089
Does it feel stronger?
Battlefresh is offline   Reply With Quote
Old 12-09-2005, 01:15 PM   #3 (permalink)
You know actually I'm really curious as to your opinion on your current setup. I'm trying to decide if I should get stage 2 or go with stage 1 and mapclamp. Do you notice big increase in power over stock with all your mods? I was going to go stage 2, 3" turboback and that's pretty much it. Think your setup is faster?
Old 12-09-2005, 01:16 PM   #4 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (44)
Preset? As far as I know, Das does not sell them pre-set for obvious reasons.
Some things are pathetic!
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 12-09-2005, 01:21 PM   #5 (permalink)
fade's Avatar
Member Number: 27861
Having it hit high 11s or right on 12 on the intial punch would be good but your higher rpm afrs won't allow it by much. Leave it like it is.
Only tune the map in 3rd. It runs leaner than 4th. If you tune in 4th for a good AFR then 3rd will be too lean.
'05 Silver SRT
Mods: GT3076R and stuff
fade is offline   Reply With Quote
Old 12-09-2005, 01:32 PM   #6 (permalink)
TrevSRT's Avatar
Yes, they are pre-set from when buying them, just tuned way down from my understanding....
Anyway, before the mapclamp I tested my afr's........(3rd gear pulls)
10.9 as soon as I lay into it, at redline it hit 11.2 max....
after the mapclamp which I just received about 2 hours ago ad just got done letting my friend soder it for me, we did the following runs that I posted in my first post. ( so obviously it is preset, or mine was).
And the first post was a mess-up, I am spiking 17.5 - 18psi and falling to 15 at redline.
Old 12-09-2005, 01:34 PM   #7 (permalink)
TrevSRT's Avatar
So you suggest leaving it like it is untill I get a fuel return line, or ptperformance's fpr mod...?
Is 12.5 afr too lean? I heard some people are letting it go this high, is that safe?
Old 12-09-2005, 01:40 PM   #8 (permalink)
TrevSRT's Avatar
Yes, it is a HUGE difference over stock with all my mods.....the car with just adding the mapclamp (which just got installed) pulls alot harder all through the powerpand.
And I don't get that feeling in 4th gear anymore that i use to before the mapclamp, it felt like it pulled alot of timing in 4th (car was really slow when switching to 4th gear, now that I have the mapclamp i don't feel that anymore.
Old 12-09-2005, 02:07 PM   #9 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
Exclamation
sorry i didnt read everything but what is your MAX boost? never mind i see its 18 psi falling to 15 you may up it just a little if you had a return line you could go to 22/23
if its 18-20
start turning the clamp to the left try 5 turns
recheck
now if its still the same
do one turn incraments until your at 10 turns 5+1+1
so 5 truns check, 1 turn check repeat till 10 turns or until you hit target a/f
if target a/f has not been reached but some changes have taken place do half or 1/4 turns
due to the nature of the stock turbo srt peak boost is hit then it falls off you will be adjusting the LOW a/f ratio not near redline do all of this in 3rd shoot for 12.0 then check in 4th
i like to get it 12.2 in 3rd hope this helps
My Space
Yea I am still around
Vector is offline   Reply With Quote
Old 12-09-2005, 02:15 PM   #10 (permalink)
fade's Avatar
Go with what vector suggests. 12.2 in 3rd. It's a good safe afr.
Vector, since he is running leaner at redline then at the initial punch wouldn't he want to lean the high rpm AFR to 12.2?
Old 12-09-2005, 02:19 PM   #11 (permalink)
MikeCandler's Avatar
Member Number: 5521
Trader Rating: (52)
Vector is the man listen to his advise
2007 Subaru WRX stock with some Buschur Racing parts
MikeCandler is offline   Reply With Quote
Old 12-09-2005, 02:20 PM   #12 (permalink)
IWantAn04's Avatar
Member Number: 3377
hey vector if i tuned for 12.0's in 70 degree weather....how much leaner would it be at 30 degree weather. Too lean i know...im just wondered how much will it change
Injen sri | AGP WGA | Progress springs
AGP motor/tranny mounts | MaxxFab side exit
CCA bfmic | Enkei RS-V 17x7's | Revitup tbars
map clamp |NGK wideband | AGP fuel return | Crane 12's
Quote: Originally Posted by 03slpr
Me either. WTF is a MAP and why do I want to clamp it? Sounds Painful.
Quote: Originally Posted by silverscooby
BTW, thats Canadian horsepower. Take 11% off of that to convert it to American Horsepower.....
IWantAn04 is offline   Reply With Quote
Old 12-09-2005, 02:21 PM   #13 (permalink)
jacobsen23's Avatar
Member Number: 17081
Trader Rating: (10)
Sorry to hi jack, but would it work to map clamp a car that is on pcm controlled boost? So the power will be increased but driveability will be maintained?
jacobsen23 is offline   Reply With Quote
Old 12-09-2005, 02:40 PM   #14 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
in order to effect the higher RPMS where he is alread in the upper 11s he will need a return line or something
and really in order to effect it your going to have some serious clamp on the car
Old 12-09-2005, 02:42 PM   #15 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
its better to be on the green or blue (i like greed line setups the most)
really it isnt the best to clamp it when the PCM controls it. because the PCM is flying blind then and it will effect the pcm's EBC and you may have erratic boost
