Old 06-10-2008, 12:37 PM   #1 (permalink)
CStyles45's Avatar
Member Number: 994
Trader Rating: (31)
Default MAP clamp wired wrong?
Hey guys, I installed my clamp a few weeks ago and I couldn't get it to work at all. I pulled it apart and this is what I saw:
The wire colors from the screw goes as follows: Black - Red - Green.
After referencing the how-to thread, the diagram looks like this:
Based off of that info, does that mean that MY:
Black wire gets spliced into the map sensor 5v wire
Red wire gets spliced into the map sensor signal wire
Green wire gets spliced into the map sensor ground wire
That look right??
Any other suggestions?
Thanks guys!
CStyles45 is offline   Reply With Quote
Old 06-10-2008, 12:58 PM   #2 (permalink)
Elected Moderator
N0sferatU's Avatar
Member Number: 9266
I thought I'd elaborate for CStyles...I used my scan gauge and it seemed to work the opposite direction of your typical MAP clamp (e.g. clamp at anything below a set voltage).
As we cranked it the MAP with the engine at idle the mmHg would climb from 18 to 17 and you can watch the air/fuel start to richen up because the increase in mmHg and when you reached 10mmHg it'd stumble like hell and eventually stall the engine if you went higher. So it seemed like as you increased the clamp it'd cut into the negative end of the ECU's reading range and not the positive end.
I mean we turned the car off and left the ignition on and as we turned the MAP clamp you can watch the mmHg climb...I brought it to as high as 5.6psi and if you tried turning the ignition no dice the car wouldn't turn over since it was trying to dump so much f'in fuel
We tried reversing the two wires to no avail...
Figured you left out some important details there...
PERSONALLY I'd just buy a new potentiometer
2004 Dodge SRT-4
Stock Turbo, Stock Fuel System, Street Tires
60': 2.11
1/4mi: 13.29 @ 110.51mph
N0sferatU is offline   Reply With Quote
Old 06-10-2008, 04:30 PM   #3 (permalink)
lessthanmike's Avatar
Member Number: 8631
is that the mapclamp i gave you???
if it is i'm pretty sure it's a dasmopar one.
it should splice this way
Black -> Orange
Red -> Green,Red
Green -> Black
05 srt-4
lessthanmike is offline   Reply With Quote
Old 06-10-2008, 07:21 PM   #4 (permalink)
Elected Moderator
N0sferatU's Avatar
Member Number: 9266
I'm already thinking he put black to black lol...
What made DasMopar think of having a black wire not match up with a black wire...
Old 06-10-2008, 07:33 PM   #5 (permalink)
CStyles45's Avatar
Member Number: 994
Trader Rating: (31)
LOL. Seriously. Ok. Its getting reinstalled tomorrow with hopefully the right matching wires.
Old 06-10-2008, 07:36 PM   #6 (permalink)
Member Number: 8631
hey colt send me your email address again and i'll send a how to thats on a different website i can't link from here
Old 06-10-2008, 07:51 PM   #7 (permalink)
Elected Moderator
N0sferatU's Avatar
Member Number: 9266
no need to take it personally I'm just laughing at how the wiring schematic is setup that's ridiculous.
Old 06-10-2008, 07:54 PM   #8 (permalink)
tonydsrt4's Avatar
Member Number: 40622
Trader Rating: (15)
Should have drove to Erabbits house..............
Mods- I wouldnt worry about it...
12.45@ 108
tonydsrt4 is offline   Reply With Quote
Old 06-10-2008, 08:24 PM   #9 (permalink)
CStyles45's Avatar
Member Number: 994
Trader Rating: (31)
LOL. I had my daughter all day so I couldn't make it. I still would like to come see all you guys and hang out for a day.
» Search Used Cars
Page generated in 0.23453 seconds with 11 queries
