Old 06-27-2008, 09:57 AM   #1 (permalink)
Member Number: 64760
Trader Rating: (10)
Default Major missfire/car shutsoff when shifting to 4th. HELP.
so i had some freeway pulls last nite with my buddies.
25psi. 50t. crower s2 cams. full bolt ons. 2 m5 nozzles of meth. race gas. 105oct SCT race map.
id go thru 2nd thru 3rd fine, but once i shifted into 4th or into mid 4th, my car would cut completely out, missfire (if i gave it gas after itd misfire and not go anywhere) then the car would completely shut off.
we switched coil packs w/ a basically brand new coil pack. did another pull, and did it again. misfire shifting into 4th, cutout, then shut off.
im completely stumped.
new stock coil basically.
mopar 7.5mm wires
and i have about 2k mile old 4306s that gave me no issue at any point in time.
only does it shifting into 4th, and no other gears.
i did a few runs earlier in the day on pumpgas/23psi and had no issue.
im stumped. what would cause it to cut/missfire so bad and then shut whole car off?
mike
DRASTIC.
91PumpKing. is offline   Reply With Quote
Old 06-27-2008, 09:58 AM   #2 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (61)
check your plugs, take a close up pic (use the macro mode - the flower mode on the digital cam) then post on here.
SCT Tuned by Kevin@AGP Turbo
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 06-27-2008, 10:03 AM   #3 (permalink)
Trader Rating: (10)
i will check them out tonite. and post.
can plugs really go bad in a matter of one pull, and enough to make it shut off? no issues till last nite. and i did a few runs earlier that day w/o problem.
Old 06-27-2008, 10:08 AM   #4 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
yes they can go bad just like that.. It can happen just regular driving
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is offline   Reply With Quote
Old 06-27-2008, 10:25 AM   #5 (permalink)
Member Number: 25021
I don't think it was the plugs. I swapped my coil onto it and it ran fine right after. Then he did a pull on the race gas tune again, and it went out again... Waited what? Five minutes? Then it ran fine home, right Mike? Sounds electrical to me. I am thinking Cam position sensor or something to that extent. In the time we swapped my coil on, it could have cooled enough to be ok... I wish it was throwing a CEL.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 06-27-2008, 10:47 AM   #6 (permalink)
Trader Rating: (10)
ya did the pull, cut out and died.
swapped coils, went for another run and same thing.
no cel...is that because of the SCT hides them?
Old 06-27-2008, 11:01 AM   #7 (permalink)
As far as I know, SCT only turns off overboost codes and such.
But after the second time, you waited what five minutes and you could drive the car home right?
Old 06-27-2008, 11:07 AM   #8 (permalink)
Trader Rating: (10)
correct on that last question.
Old 06-27-2008, 11:17 AM   #9 (permalink)
Pizza Boy's Avatar
Member Number: 49788
Trader Rating: (58)
sounds ecu related, if it happened in any other gears i would think other wise, i don't see any other way of it being proprietary to just 4th gear.....
Quote: Originally Posted by raven View Post
i'm 23 and live in my parents basement.
i could land a much better looking dude than you.
Pizza Boy is offline   Reply With Quote
Old 06-27-2008, 11:19 AM   #10 (permalink)
But the car wouldn't run correctly afterwards in any gear. Mike, try swapping the tunes. Just for shits and giggles and see what happens.
Old 06-27-2008, 11:23 AM   #11 (permalink)
Pizza Boy's Avatar
Trader Rating: (58)
i would agre with that, switch the tune and see what happens...
Old 06-27-2008, 11:25 AM   #12 (permalink)
Trader Rating: (10)
yea.
it only happened after i switched to my 104oct SCT race map.
ima need to talk to nemiro about that...
on a side note, i use to have issues shifting to 4th way back in my sst days. id shift fast to 4th...and it would just blow-out. as if i popped an IC hose off. id get off the gas, then get on and itd be perfectly fine.
stumped to say the least.
i got THREE nails in my tire last nite...so i cant drive the car right now till its fixed sinces its dead flat.
Old 06-27-2008, 12:00 PM   #13 (permalink)
Pizza Boy's Avatar
Trader Rating: (58)
LMAO@ 3 nails...my god that is bad...were you driving thru a hardware store or construction site?
Old 06-27-2008, 12:26 PM   #14 (permalink)
Trader Rating: (10)
dude...no fuckin clue. completely random. and completely fucked up. these tires only have like 100mi on em
Old 06-27-2008, 01:17 PM   #15 (permalink)
Pizza Boy's Avatar
Trader Rating: (58)
i got 50,000+ miles on my stock KDW's before replacing them 2 months ago...
