Quote: Originally Posted by
romanss
Thanks guys.
This is what I was looking for.
I assume that I can enable/disable the AVC-R, correct? It looks like there is one unit, so this will work on any turbo car? There isn't a SRT4 specific unit, correct?
Also how do you program it? Do you have to do it real world, or set it up and give it a try.
Forgive me for my questions.
Thanks alot,
Roman
It's universal, no "SRT-4" specific model.
Read the installation instructions
carefully.
If they haven't updated the instructions since I bought mine, you'll be able to tell that it was translated from another language (not quite as bad as "All your base belong to us" but close).
I would turn off the "auto-learn" and at first work with the duty cycle. Start with 20% and see what the boost is, then maybe do 40%. Keep incrementing until you're boosting what you want in 3rd & 4th gear. Then go back and mess with the individual gear settings (after you setup the gear steps, which you'll need to do driving, follow the instructions the best you can there).
After you get it pretty close to the way you want it, then you can turn on the auto-learn, but only in the gears you want full boost (3rd, 4th & 5th most likely).
IIRC, I had 1st gear auto learn off, with the maximum taken out of the duty cycle. In 2nd gear auto learn off, with about 20-30% taken out of the duty cycle. In 3rd+ auto learn was off and 0% taken out of duty cycle. Base duty cycle was set around 50%. All of this w/ a 15psi WG spring gave me: ~16-17psi in 1st gear (still way too much), 17psi climbing to 19psi in 2nd, and 23psi in 3rd +.
