Quote: Originally Posted by Lagzilla
so if there is say 7 deg of knock retard that doesnt mean its dangerous, it just means you could do things to gain your timing back
Yes and no... The computer will take active measures to reduce and prevent detonation. That being said, it is still safe, but the car is still detonating. Detonation is NOT safe and hard on pistons. Remember, your not the first big turbo car on the block.. Many big turbos are out there, and have been running fine without problems, although I am sure under those increased pressures in the cylinder, they are experiencing a little bit of detonation, just like you.
for lets say us big turbo guys the less timing and more boost will yeild more power compaired to stock turbo.
Over the stock turbo sure.. But your thinking is backwards... MORE timing and MORE boost = MORE power. But there is a flip side. MORE timing and MORE boost = MORE prone to detonation, keeping all other variables as close to constant as you can.
Idealy, the rule of thumb is if you increase cylinder pressure, you want to retard timing. We have no way to do that in the SRT4. Infact, piggyback AFC's actually INCREASE timing while we increase cylinder pressure. When you think about this, our entire engine must be built by some of the best engineers on the planet.. Think about it, we have 500+ whp SRT4's running on stock internals and AFC's. The programming in the NGC
HAS TO BE extremely conservative, and the engine must be built like a rock. Running into a little ping at those levels would normally be deadly.
so if we are running 20 psi on pump and pulling 6 deg of knock retard
that is still safe correct? because there is no knock.
No.. If the NGC is pulling 6 deg of retard, its due to something. The aero force guys have already chimed in and said that its due to knock. So, is it safe... Seems to be. Because there is no knock? Absolutely incorrect. The engine is experiencing detonation (knock) and taking corrective action to reduce timing advance to keep the pistons (and your wallet) happy.
even more so if there is 9 deg of knock retard, that is still "safe" because its doing its job in order to eliminate knock, and still making more hp then if oen were to pull boost down to say 17 psi and run more timing.
The safest knock retard to shoot for is zero. 9 may not be safe, and it definately will not produce as much power as zero. Will it make more power than 17psi and more timing. Thats only something you can find out on a dyno, and with an EMS system that will allow you to control timing. Your afc will not let you do that without SERIOUS modification.
Think about it like this... All the stage 0 guys who slap on an AGP wga without any kind of afc.. What exactly are they doing? They are increasing cylinder pressure, and allowing the computer to see it. What do we know about AFC's? They hide cylinder pressure from the computer. This increases timing advance and leans out the mix. Now, remember in our scenario, there is NO afc.. So, the computer sees the increase in pressure. We know that decreasing pressure causes a leaner mix and more timing... Take that the other way, increasing pressure and allowing the computer to see the increase in pressure
MAY cause a reduction in overall timing advance and a richer fuel mixture. The final result? Their agp wga SRT4 can't run much faster, if ANY faster than a stock SRT. And I have proved this at the strip time and time again.
Timing advance (even though you can't control it with an AFC) is JUST AS important as the amount of air you shove into the cylinder.
the ideal way to run would have much higher octain to allow the computer to give you the extra timing + the amount of boost you want.
again, deg of timing retard is not dangerous but is not ideal?
Runing higher octane gas does not allow the computer to give you more timing. It just allows the computer to continue to advance timing further than pump gas. As you increase timing, you are increasing cylinder pressure... Increasing cylinder pressure increases the likelyhood of detonation with all other variables held as close to constant as possible. The higher octane of race gas helps eliminate detonation.
In your situation, I would say the deg of knock retard you are running into is not a problem. Knock retard is definately not ideal, and if you solved your detonation problem, you would gain more advance and thus more overall power.
Please let me know if I need to be corrected anywhere in my thoughts. I am not a timing expert, and you have throughly exhausted my knowledge of timing, but I believe my thoughts are spot on. Please advise if you think otherwise.
TJ
