Old 01-03-2005, 11:34 PM   #1 (permalink)
wfosrt's Avatar
Member Number: 2499
Default Installed LM-1 wideband today... need help with AFRs.
Long story short. I just finished installing it a little while ago and I have two questions..
1. Is the AFR in 1st and 2nd really lean???
In 3rd and 4th gear it seems to be running correctly. It starts of around 11-12:1 afr at like 3000-3500rpms and then quickly goes down to the low 10:1 afr to redline.
In 1st and 2nd it is like in the 14:1 AFR.
2. I have S2 and realized that the check engine light is on. If I didn't leave the old 2nd O2 sensor plugged into the connector can that cause the CEL?
03' BLACK AGP 3147 Turbo kit. AGP 750cc fuel kit, AGP Spark Plugs
(14.5psi)297WHP/289WTQ
RIP: 6/5/05
94' EJ1 (d16z6 turbo)
wfosrt is offline   Reply With Quote
Old 01-03-2005, 11:36 PM   #2 (permalink)
red
red's Avatar
Member Number: 2869
yes removing either o2 sensor will cause a CEL. The comp doesn't see the sensor.
“DO NOT TAKE LIFE TO SERIOUSLY; YOU WILL NEVER
GET OUT OF IT ALIVE....” -Elbert Hubbard
red is offline   Reply With Quote
Old 01-03-2005, 11:41 PM   #3 (permalink)
Project Blue
SRTforums Admin
Member Number: 1161
1) is this under WOT or during daily driving conditions because our cars run at 14.7 while cruising. and whats extremely lean?
need more info.
2) Yes it can cause a CEL
http://www.hybridsrt.com
In remembrance of Andrew "HybridKid" Chin Shue
In remembrance of Steven "NightShade" Lorenz
FastAttack is offline   Reply With Quote
Old 01-03-2005, 11:41 PM   #4 (permalink)
wfosrt's Avatar
Member Number: 2499
Thats what I figured. With S1 and S2 it doesn't really use the 2nd O2 sensor but will probably not like it to just be unplugged.
Old 01-04-2005, 12:06 AM   #5 (permalink)
red
red's Avatar
Member Number: 2869
It still turns on the heater circuit if I remember correctly. And it still can sense the signal return for voltage. I don't think it cares what that voltage is just as long as it see's something reasonable.
Old 01-04-2005, 12:11 AM   #6 (permalink)
wfosrt's Avatar
Member Number: 2499
I will plug it back in tommorow and try to secure it somehow to the underbody.
know anything about the AFR thing?
Old 01-04-2005, 12:33 AM   #7 (permalink)
red
red's Avatar
Member Number: 2869
Well I can tell you if you have just s2, 14.1 across the board is bad if your at w.o.t.
if your cruisin' thats fine. you should see something like 11:1 or lower with factory boost.
EDIT: I just looked at your mods..... what kinda boost are you runnin?
Old 01-04-2005, 12:36 AM   #8 (permalink)
wfosrt's Avatar
Member Number: 2499
I'am running Stock S2 boost.
I run rich ~10:1 afr in 3rd 4th 5th gear.
Old 01-04-2005, 08:08 AM   #9 (permalink)
RoostBoost's Avatar
Member Number: 7368
Trader Rating: (72)
I've seen a couple of stage 2 cars go off the AF chart on the dyno~ less than 10:1 on the AF meter
RoostBoost is offline   Reply With Quote
Old 01-05-2005, 09:13 PM   #10 (permalink)
thunder6g's Avatar
Member Number: 12672
Trader Rating: (60)
http://srtforums.com/forums/showthread.php?t=106369
http://srtforums.com/forums/showthread.php?t=96130
Search and read up, then pm some of the people who have run into these problems and see what they found out would be a good idea
thunder6g is offline   Reply With Quote
Old 01-06-2005, 10:07 AM   #11 (permalink)
wfosrt's Avatar
Member Number: 2499
I got it figured out.
I guess I wasn't really watching the moniter right. It will go from 14:1 then like 12ish:1 when you first get on it then 10-11:1 afr in 1st and 2nd.
So it runs a tad leaner in 1st and 2nd do to the less load and lower egts.
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.19399 seconds with 13 queries
