Old 12-02-2005, 11:57 AM   #31 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
Would you agree with my write up?
There are several things that can control how timing is affected. Typically if all conditions are right the PCM will advance timing to the point at which knock is detected and the PCM will back off a few degrees and hold steady. This is because too much timing will cause denotation. If all conditions are met you should advance all the way to redline. If the PCM begins to pull heavy timing it’s usually because knock is present. Now the only way to see this is by some type of timing logger or a data logger which is mostly used. So therefore you should think on ways to prevent knock. First of all you must know what knock is. You've probably heard knock used in serveral terms; knock, detonation, or adnormal combustion. Knock occurs because the pressure and temperature in the cylinder are high enough when combustion is occuring that the unburned fuel and air mixture spontaneously ignites. Now you can also have pre-ignition. Pre-ignition is where you have carbon deposits or metal within the cylinder chamber that actually stay with the chamber even after the exhaust cycle is complete. The depostis are usually still very hot and as the intake stroke completes the glowing hot deposits cause knock. Pre-ignition is not common because of the DOHC system. Ok back to the subject, you want to prevent knock by controlling the pressure and temperature level within the cylinder. Now there are several causes of detoniation. Because of our CR of our cars it isn't necessary to get into pressure levels, however, do remember that it can play a role. Times to consider replacing pistions should be after 450hp just due to the stock pistion and rods not being able to hold this type of hp. Secondly, if you are running 27psi or more you want to consider a lower CR. Therefore temperature levels will be the main concern. The rise in temperature levels could occur in one or many differenet ways.; very lean A/F ratios, heating of the air intake charge, high compression of psi levels, or poor heat dissipation through the cooling system. Oh one more thing to add, a low octane gasoline will cause knock at high boost levels. The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. Therefore you want to run a high octane gas to prevent knock. 91 or 93 is good enough. Remember all this is going to refer back to how timing is pulled. Ok back to rises in temperature levels.
Possiblities of Timing Being Pulled
The problem - Very Lean A/F Ratio
The Solution - Turn boost down - turn that BC down and/or the WGA adjustment nut down; Get more fuel - fuel pump, fuel return line, big injectors along with SAFC/Powerpaq/Dtec/Emanage/Etc. Also a very lean condition will cause your EGTs to go up.
The Problem - Heating of the Air Intake Charge
The Solution - Get a CAI (some will argue this); Get a bigger intercooler; Get water injection
The Problem - High Compression Boost Levels - this usually relates back to lean A/F conditions or heating of the air intake charge. Remember that air heats when compressed
The Solution - Again back to turning the boost down, get a bigger intercooler or W/I
The Problem – Low Octane Fuel
The Solution – Run higher octane fuel;
The Problem - Poor cooling
The Solution - Most of this was solved for us for factory. This included the oil squirters that spray oil underneath the pistions to cool them. Using a lower degree thermosat will decrease cooling temps but I haven’t been able to confirm if this will put the car in an open loop mode or even a limp mode.
Now you still may have knock and not even no it. Small amounts of knock it not harmful, heavy knock will have severe damage to you engine. You’ll need to have ways to know if knock is present. First way is to listen yourself. It is usually heard as a pinging sound. Second, with the OBD system the car will recognize knock and display it as a CEL. Third have some type of knock monitoring system. The SAFC is capable of monitoring knock but to my understand it won’t work because of the voltage readings. Fourth, the sparkplugs. Look for small shiny specs. This can be from tiny carbon and metal deposts that stay within the chamber glowing hot. This is commonly known as pre-ignition.
So to make a longer story short:
Detonation, aka Knock, is an when the air and fuel ignites before the the spark plug ignites. Heavy knock can cause severe engine damage. Knock is controlled by the ECU retarding timing (pull timing). If timing is pulled it because knock has been detected. The ECU will advance timing until knock is detected. Once detected it will pull a few degrees and maintain while slowly trying to increase again. Causes of knock is from high cylinder pressure and high temperature pressures. These can be maintained by using high octane fuel, bigger intercooler, water injection, idea A/F ratio, cold air intake, etc. Heat is your enemy! Using a datalogger you can see how much timing is advancing and if timing is being pulled.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 12-05-2005, 09:49 AM   #32 (permalink)
SRT-4FUN's Avatar
Member Number: 17915
Quote: Originally Posted by blackbird_R/T
All the computer is doing is running calculations (kind of like a cause-and-effect: cause- determine MAP, A/F, charge temps, etc. and how they interact) and doing something according to formulas (effect- add fuel, run more boost, pull timing, etc.). What you've done is change part of that formula and the PCM doesn't know better. If you removed the sensor that's near the air box inlet and warm it up, the computer thinks it's hotter outside. Because of the temperature actually being lower though, the intercooler should be working more efficiently. So that means that the intake charge temp sensor (on the UPP right before the throttle body) will be telling the computer the charge temps going into the engine are OK. So as long as you're running a quality fuel, you should get that little extra boost, and because the charge temps are lower than normal, you'll also get the same or a little better timing advance.
Now if the weather was hot outside and you trying to trick it into thinking it's hotter yet to get more boost you might start to see problems. The intercooler wouldn't be working as efficiently in summer for example, and if you tricked the sensor to provide more boost pressure the actual intake charge temps would be higher. That would increase the chance of detonation, which would hurt power output. But I doubt that would even be a big problem unless you had the sensor max'd out or were doing something else like running a MAP clamp at the same time. If it was hot out, you'd be getting more boost anyway and the computer is still determining timing from other things like the intake charge sensor.
For now you should be fine. If you start trying to wire things in-line with the sensor without a means to watch and test what you're doing you could cause it to run worse, but probably wouldn't kill the engine. The inlet air temp sensor shouldn't be able to affect/make that broad of boost changes that the knock sensor and intake charge temp sensor wouldn't compensate for.
this guy is one of the few people in this entire forum that knows what hes talking about. !! im at a loss of words
SRT-4FUN is offline   Reply With Quote
Old 02-23-2006, 02:32 AM   #33 (permalink)
SRT Videos Moderator
Lagzilla's Avatar
Member Number: 4098
Trader Rating: (26)
sry to bring a thread back to life but... question
on my car i run a 50 trim with st0(Stock computer) 650cc injectors a return line at 42 psi, and a walbro fuel pump running just under 20 psi
how is timing affected by my mods? and how much do you think it is running? ive read that some st0 cars run about 25 degrees of timing, after tuning a few DSMs ive noticed thats quiet a bit of timing anythots ?
06 Honda S2000 Rio Yellow Pearl - K&N FIPK II
SOLD - 04 AEM EMS'd SRT
XBOX LIVE - "LawStudentLaggy"
Lagzilla is offline   Reply With Quote
Old 02-23-2006, 02:39 AM   #34 (permalink)
SRToc Member
The-Violator's Avatar
Member Number: 3510
Better bust out my reading glasses.. Eric's posting his mini-novels again..
-Jason
The-Violator is offline   Reply With Quote
Old 02-23-2006, 08:58 AM   #35 (permalink)
L0c0's Avatar
Member Number: 19414
Trader Rating: (29)
Wow...good info...subscribing for any updates
L0c0 is offline   Reply With Quote
Old 02-23-2006, 09:17 AM   #36 (permalink)
Trader Rating: (37)
If I am not mistaken you should worry to much about timing with the bigger turbo kits. Tuning for timing should be watched with stock/S3 turbo. Really because of the increase in cylinder pressure from a higher volume of air being boosted into the engine.
Old 02-23-2006, 09:18 AM   #37 (permalink)
Trader Rating: (37)
Actually I think this is a good thread to bring back up.
Old 02-23-2006, 09:26 AM   #38 (permalink)
Member Number: 5369
First off, I'll copy your mods below for future reference in case you change your sig and I'm trimming out items not related directly related to power/tuning:
AGP T3T4 50 trim .63, Turbonetics Evo wga, AGP fuel return, SAFC2, 650cc RC's, 255walbro, JoePMBC@18psi, 60mm T/b, Griffen big FMIC, PUMP GAS@17PSI 10.9-11.1A/F 364WHP 348WTQ
Looking at that list the first thing I notice is your S-AFC, but we'll get to that in a minute. The stock (S0) PCM as well as the Mopar "Stage" computers on the SRT-4 run quite a bit more timing advance than what you'll usually find on many other turbocharged vehicles. The stock computer for example will run around the lower to mid 20°'s advance in the mid-range during a WOT pull and start to advance it even more towards redline, ending up around 29-30° on a stock car. That's quite a bit of timing advance but it works reasonably well with the small stock turbo.
Talking about a stock car, Chrysler added and designed a few things that make running that much timing advance possible. The compression ratio is relatively low, it requires premium fuel, the intercooler works well, the PCM has a good knock detection system, etc. The turbo also isn't moving huge quantities of air so the overall cylinder pressures aren't too high (again remember that when talking about different turbochargers you need to think in overall airflow and not boost since boost is just a measure of pressure or restriction to flow).
Before going off too far it might be good to talk about what timing is and how it affects power. In an engine you have pistons moving up and down in their bore that are connected to the crankshaft by connecting rods. Their movement rotates/spins the crankshaft which in turn eventually drives the wheels. The pistons gets forced downwards by an ignition of the air/fuel mixture that comes into the combustion chamber when the intake valve opens. The piston comes up and compresses that mixture and the ignition system fires the spark plug to light it. And in our case a turbocharger is forcing more air into the engine so you can in turn burn more fuel. That creates a bigger 'explosion' that creates more force pushing down on the piston which creates more twisting force (torque) at the crankshaft.
So timing is the actual point in time when the air/fuel mixture gets ignited. That reference point is measured in degrees rotation of the crankshaft, with the piston at top dead center (TDC) being 0° (out of 360° total that's in a complete circle). TDC is the exact point between when the piston is still coming up and when it starts going back down. Here's where timing advance comes into play.
When you go to fire the spark plug to ignite the fuel it doesn't all immediately go from not burning to fully burning. If it did that you would have detonation, or uncontrolled spontaneous ignition/burning of the mixture. It takes a little bit of time for the flame front that's created to spread out and fill the combustion chamber. So what happens is the spark occurs and starts to light the air/fuel mixture as the piston is still coming up. This is measured in degrees of timing advance before top dead center (BTDC). Remembering the 360° to a circle that the crankshaft has to turn when making one revolution, if you have 15° timing advance, the ignition is lighting the mixture off 15° before the piston has come all the way to the top (or 345° into the rotation). The flame starts to spread out and burn (with the gasses expanding and increasing in temperature) after a certain amount of time and it eventually starts pushing down on the piston which forces the crank to continue spinning. If it happens correctly the mixture is lit and the flame front that's created travels throughout the combustion chamber (the area machined into the cylinder head and between the top of the piston) and starts to push down on the piston with maximum force slightly after top dead center (ATDC).
If you light the mixture too soon (too much timing advance) it can start pushing down on the piston before it has a chance to reach the top of its stroke. That would be the equivalent of trying to stop the crankshaft and lower end rotating assembly and make it turn the opposite direction. What normally happens with too much advance is that the mixture spontaneously combusts at once which creates a large spike in cylinder pressure that's called detonation. It causes the engine to vibrate which you can hear as 'knocking' if it's loud enough. If you light the mixture too late (less timing advance, which would happen if timing is retarded/pulled), the flame front in the combustion chamber doesn't reach its peak pressure until the piston is well past AFTD and it doesn't transmit as much of that force into mechanical energy. You end up with a lot of that heat energy being wasted out the exhaust, which is why EGT's go up when you run less timing (such as when it get pulled/retarded due to something like knock).
If you were to look at the timing curve on a naturally aspirated engine you'll probably see the timing being advanced as rpm's go up. This is because the fuel generally burns at one fixed rate of speed, but the piston is moving faster. To keep that optimal power where the combustion forces are pushing down right after TDC you need to light the mixture off sooner (more advance) since there's less time for the flame to spread when the piston speed increases.
A forced induction application is usually a little different. Out of boost it may behave similarly to a N/A engine (which is why you'll see a lot of advance cruising with the engine in vacuum), but when you come into boost the cylinder pressures start to increase. The higher the pressure, the greater the temperatures in the chamber. The greater the temperatures, the greater the chance for detonation. In order to limit the chance of that happening you need to reduce timing.
The SRT-4 uses a DIS (distributorless/direct ignition system) where the PCM/computer controls when the timing events occur. It's programmed for the air flow ranges of the stock turbocharger and also considers things like charge temp, MAP pressure/vacuum, barometric pressure, coolant temp, etc. when determining advance. When something like the charge or coolant temps go up it knows there's a greater chance the air/fuel mixture will want to ignite. So if we're doing a wide open throttle (WOT) run through the gears, at the higher loads in the lower part of the rev range where detonation is more likely to occur it reduces timing. But with the stock turbo dropping boost up top, the decent stock intercooler, and premium fuel it can advance timing a little to make better power without running into detonation.
Now let's say you have a big turbo. Most of them start flowing a greater quantity of air on top which leads to a higher cylinder pressure (higher cylinder pressure is the equivalent of increasing the compression ratio), which also increases temperatures. The more you compress a gas the hotter it gets. You're trying to burn more fuel as well to go along with that extra air and then get a bigger "bang". Because of this and other factors you usually don't want that much timing advance, especially on the top end when the big turbo is just starting to get spooled up. One of a few things is going to occur. First, if you're running a high enough octane fuel it might be able to take advantage of either some or that entire amount of timing advance a stock turbo car runs, also depending on how much boost/airflow is being produced. The higher the octane fuel, the slower it burns so you can ignite it earlier to take advantage of maximum power without getting detonation.
Second is that you will get some mild detonation but the PCM reacts fast enough when it hears it via the knock sensor. It will then pull/retard the amount of timing advance its running. If it's just mild detonation you might not have a big problem. Now let's say you tricked the PCM by altering one or more of its inputs such as the MAP signal. What's going to happen if the PCM thinks that it's operating under one condition and isn't expecting knock due to its programming when in fact you've just tricked it? You could potentially get bad detonation because it doesn't react fast enough and it damages the engine (such as fracturing the top ring or ring land of the piston that normally seals the piston to the wall of the block). And on an engine with high specific output even small detonation can be very hard on things like the rod and main bearings, and we haven't talked about the oil pump, etc.
A third scenario is someone could be running water or alky injection to limit the chance of detonation and take advantage of the timing. Depending on the mixture being injected it can either add fuel (alcohol to richen the mixture in the combustion chamber) and/or help take heat out of the combustion chamber (works similar to an evaporative cooler where it absorbs some of that heat in the chamber in order to change the liquid to a gaseous state). If it was running lean and subsequently hotter the alky can help, and if it's just too hot the water helps to a certain extent. But if you use it to suppress detonation and it suddenly fails at high boost the PCM may not be able to correct (reduce) timing and catch the detonation in time if a component in the water injection system fails.
Those are a few ways some of the big turbo cars are running. It would be great to have a lot of timing advance like the stock turbo can use but in reality it's hard to control detonation with the increased airflow, so you should be running less advance, especially on pump gas and higher boost. And if you aren't doing it the PCM probably is (because of detonation/knock). Things like a bigger intercooler to help keep charge temps down and adding fuel can help, but only to a point. The maximum timing you can run will depend on mechanical properties, so if you don't want to further lower the static compression ratio you end up running less timing in order to push a lot of boost on a big turbo.
Finally back to the S-AFC or any piggyback/MAP clamp for that matter. An optimal tuning solution for the piggyback would be to adjust fuel first, such as changing fuel pressure, and then use the piggyback to fine tune. The bad thing about how it works is that if you end up having to remove or take out excess fuel to get an A/F you want the PCM is going to see less boost. When it thinks there's less boost it will try to running more timing advance because it expects that there's less air going into the engine and less chance for it to knock/detonate. So if you have a big turbo you might be starting out with too much timing due to the stock or "Stage" PCM's and then getting even more advance because the PCM isn't even seeing the full boost it was designed to read.
In your case RC rates their injectors at the industry standard 43.5 psi unlike Mopar which is at ~58 psi. So at 42 psi you're getting nearly the full 650 cc/min of fuel. If you have a rising rate fuel pressure regulator, at 20 psi of boost you'll have 62 psi fuel pressure and the RC's will be flowing nearly 775 cc/min. If that's enough fuel for the peak power and airflow requirements while staying maybe slightly rich with a margin of safety it might work fine. But as the boost and subsequent fuel pressure is ramping up together, if it runs rich at any point and you have to take a lot of fuel out by using the piggyback you'll get more timing advance. And if knock occurs then you've pushed it too far. You're also trying to idle with much bigger injectors and the PCM will have to alter long and short term fuel trims to correct for it (which it can also alter at other rpm range/MAP voltage levels).
On pump gas I'd rather run more boost with less timing advance to make power rather than a lot of timing and slightly less boost. The more timing/less boost method may work as a lot of SRT-4 owners with aftermarket turbo's have experienced, but it's far from being the safest way to get the same power. There are certain limits to the fuel octane and even reducing timing can't overcome them if the cylinder pressures get too high (e.g. a lot of boost on a big turbo). It amazes me how well these cars hold up at times with some of the tuning methods in use. On my scan tool I've seen 400+ whp cars at high boost that are running over 30° timing advance on top. About the only thing that's most likely holding the engine together was C16 race gas at those power levels. And because of that timing your "tune" has very little margin for error. A lot of cars hold up, but there's a lot more you don't hear about that have experienced failures trying to push stock/modified components too far.
Old 02-23-2006, 09:56 AM   #39 (permalink)
Member Number: 319
This page on ION sensing explains quite a bit of ignition timing theory: http://www.fs.isy.liu.se/~larer/Projects/main.html
Here's a snippet:
Spark Advance and Cylinder Pressure
The spark advance is used to position pressure development in the cylinder such that the combustion produces maximum work. Under normal driving conditions the mixture is ignited around in crank angle before the piston has reached top dead center (TDC), and the pressure peak comes around 20 degrees after TDC. In Figure 4 three different pressure traces, resulting from three different spark timings, are shown. Earlier spark advance normally gives higher maximum pressures and maximum temperatures that appear at earlier crank angles.
Figure 4: Three different pressure traces resulting from three different spark advances. The different spark advances are; SA1: spark advance before top dead center (TDC), SA2: before TDC, SA3: before TDC. The optimal spark advance is close to SA2.
The optimal spark advance for maximum output torque is close to SA2 for the operating point in the figure, and the resulting peak pressure position lies around after TDC. With too early ignition timing the pressure rise starts too early and counteracts the piston movement. This can be seen for the pressure trace with spark advance SA1 where the pressure rise starts already at due to the combustion. There are also losses due to heat and crevice flow from the gas to the combustion chamber walls, and with an earlier spark advance the loss mechanisms start earlier reducing the work produced by the gas. Higher pressures give higher temperatures which also decrease the difference in internal energy between the reactants and products in the combustion, thus resulting in lower energy-conversion ratios. The heat loss mechanisms and the lower conversion ratio can be seen in Figure 4, at crank angles over , where the pressure trace from the SA1 spark advance is lower than the others.
Too late ignition gives a pressure increase that comes too late so that work is lost during the expansion phase. In Figure 4, the pressure increase for spark advance SA3 starts as late as at TDC. But work is also gained due to the later start of the effects mentioned above, which also can be seen in the figure. The pressure trace from the spark advance, SA3, is higher than the others at crank angles over . However, this gain in produced work can not compensate for the losses early in the expansion phase.
Peak Pressure Concept
Thus, optimal spark advance positions the pressure trace in a way that compromise between the effects mentioned above. To define the position of the in-cylinder pressure relative to TDC, the peak pressure position (PPP) is used, Figure 5. The PPP is the position in crank angle where the in-cylinder pressure takes its maximal value. There also exist other ways of describing the positioning of the combustion relative to crank angle, e.g. based on the mass fraction burned curve.
Figure 5: The PPP (Peak Pressure Position) is the position in crank angles for the pressure peak. It is one way of describing the position of the pressure trace relative to crank angle.
Old 02-23-2006, 01:42 PM   #40 (permalink)
Lagzilla's Avatar
Member Number: 4098
Trader Rating: (26)
wow... good info...
kinda sux they dont have the ems out yet... i really dont like running the safc any more
Old 02-23-2006, 11:33 PM   #41 (permalink)
-=TWITCH=-'s Avatar
Member Number: 22217
Check out this link they just released the guage that can moniter knock/timming
http://race-tech-designs.com/store/p...cat=254&page=1
Chris
/Custom 3" Side exit/ K&N Drop In /Motegi DPK 19's/ Yokohama Parada Spec 2 235/35/19/
-=TWITCH=- is offline   Reply With Quote
Old 02-24-2006, 12:14 AM   #42 (permalink)
Satellite's Avatar
Member Number: 11813
Trader Rating: (56)
This just explained a question I was going to ask (glad I searched)!
When I'm running at the track, and do some runs right after one another, I would always notice WOT boost (and some power) falling as I would go through the gears each run. Boost might even go from 14psi down to 9psi after 2-3 runs. When I would head home and cruise for a while then get back on it, my boost would magically come back. I knew it had to do with the PCM changing something, but this puts it all together. Thanks!
Satellite is offline   Reply With Quote
Old 02-24-2006, 07:36 AM   #43 (permalink)
Member Number: 5369
Here's another good article on in-cylinder ionization sensing. Saab has been using it for years in their Trionic engine management. A benefit is that it can control timing and fuel on a per-cylinder basis much more accurately and can do things like alter injector pulse-width during a single combustion cycle if an input changes and it can also correct for knock by adjusting timing on the next combustion event in the cylinder it was detected (much faster than the conventional piezoelectric microphone knock sensing systems that have a slight delay).
http://www.visteon.com/utils/whitepa...03_01_3149.pdf
Old 02-28-2006, 10:00 AM   #44 (permalink)
acancelledczech's Avatar
Member Number: 35576
I just got the race tech timing guage, pretty cool. I am learning the timing factors now...in idle, i get timing up near 50 degrees around 3k, and at WOT, my timing falls then steady builds to redline...around 28ish (only thing i don't like about the guage tuning, driving at the same time!)
acancelledczech is offline   Reply With Quote
Old 02-28-2006, 10:04 AM   #45 (permalink)
Member Number: 10600
Trader Rating: (66)
wow... good info...
hydra is available for those that want an ems and dont want to wait...
Jeff B.
Jb@slowboyracing.com
724-349-8417 x16
Jeff@Slowboy is offline   Reply With Quote
