Old 09-27-2009, 04:23 PM   #1 (permalink)
Ridebmx18's Avatar
Member Number: 59720
Default How much can I expect from DSP??
Alright.....Looking at getting a DSP for now until I get my 50trim kit come spring...Wondering how much I can expect to benefit from the DSP performance wise?? Diablo told me 30whp...!!???? Not knowing anything about tuning yet....Prolly will try precanned 93 tune.... Is the DSP worth my money?
These are the mods I have:
SS brake lines
Stage 1 PCM
AGP WGA w/ stiffer spring
MPx 3" full turbo back including o2
JMB 3" intake
AGP Catchcan
Maddog STS & booger bushings
BWoody MMs and trans mount
MSD coil pack & wires
Dual aeroforce scan gauges
AEM Wideband (afr currently at idle 15.2-15.5)
JMB Hardpipe kit w greddy rs bov
MPx intercooler
MPx 62mm throttle body
Ported intake manifold
Walbro 255 pump
Ridebmx18 is offline   Reply With Quote
Old 10-01-2009, 03:13 PM   #2 (permalink)
Member Number: 25857
since you are stage 1 i think the dsp 93 perf tune it comes with will get you some extra power
H22-T is offline   Reply With Quote
Old 10-01-2009, 09:23 PM   #3 (permalink)
Member Number: 72493
i just picked up the dsp and i have pretty much the same mods as you, i felt a pretty big difference in a few areas i for sure think its worth your money 7k ish revlimitler is sweet! lol
FR Stage 1 05
A Few goodies
268hp 301tq @17psi
prkskir412 is offline   Reply With Quote
Old 10-01-2009, 09:35 PM   #4 (permalink)
16Boosted's Avatar
Member Number: 65234
You will get lots of great things with the diablo... but remember that you will need a master to make DA srt go evil!!
16Boosted is offline   Reply With Quote
Old 10-01-2009, 09:36 PM   #5 (permalink)
16Boosted's Avatar
Quote: Originally Posted by prkskir412 View Post
i just picked up the dsp and i have pretty much the same mods as you, i felt a pretty big difference in a few areas i for sure think its worth your money 7200 redline is sweet! lol
What cams are you running?
Old 10-01-2009, 10:00 PM   #6 (permalink)
^x2 7200 redline better have some headwork done. this aint no honda.
Old 10-01-2009, 10:02 PM   #7 (permalink)
none why? unless something is messed up my revlimiter use to be around 6ish now 7ish just from flashing the 93tune. .
Old 10-01-2009, 10:04 PM   #8 (permalink)
edited my first post lol sorry
Old 10-02-2009, 03:26 AM   #9 (permalink)
just because the diablosport has a option to raise your rev limit to 7k or higher doesn't mean you should, especially with a stock head.
Old 10-02-2009, 09:43 AM   #10 (permalink)
understandable
Old 10-07-2009, 06:56 PM   #11 (permalink)
Ridebmx18's Avatar
Got the DSP...Sold my stage 1 and went back to stock pcm....Kinda regreting that. Had a p0234 overboost code even w 93 perf tune (stage1 helped those codes). Went ahead and removed redline vac. to coldside and so far havent seen it since. Now looking for a custom canned tune... Still seems sluggish midrange... Hasnt seemed snappy midrange since I put my 62mm t-body on....
Old 10-07-2009, 09:19 PM   #12 (permalink)
duster360's Avatar
Member Number: 45182
Quote: Originally Posted by Ridebmx18 View Post
Still seems sluggish midrange... Hasn't seemed snappy midrange since I put my 62mm t-body on....
Then put the stock t-body back on.
duster360 is online now   Reply With Quote
Page generated in 0.20451 seconds with 13 queries
