Old 06-01-2008, 02:32 PM   #1 (permalink)
Member Number: 9221
Trader Rating: (18)
Default High knock with cutout open
I am getting 6-7kr with my cutout open but when its closed i get 1.5-3kr whats going on?
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 06-02-2008, 07:30 PM   #2 (permalink)
The Shadow's Avatar
Member Number: 18886
Your running leaner.
11.09 @ 132.38mph MB's fastest FWD
The Shadow is offline   Reply With Quote
Old 06-04-2008, 02:59 AM   #3 (permalink)
Member Number: 7593
I agree, hell.. your tune is already off if its knocking with it closed!!!
Nosfurato is offline   Reply With Quote
Old 06-07-2008, 06:49 PM   #4 (permalink)
Member Number: 9221
Trader Rating: (18)
AFRs are in check
Old 06-08-2008, 08:54 AM   #5 (permalink)
The Shadow's Avatar
Quote: Originally Posted by AnotherNeon View Post
AFRs are in check
What is "in check"? 10.5? 11.0? What is your A/F at WOT with dump closed?(do a 3rd gear pull) What is your A/F at WOT with dump open?
Old 06-08-2008, 01:52 PM   #6 (permalink)
Member Number: 9221
Trader Rating: (18)
DOnt know since i cant really pay attention to the gauge and the road, but i can tell you they arent higher then 12.0 at redline. Also i did a 3rd gear pull today and no knock. However, during normal driving my knock in 5th gear at 50mph was holding at 1.5kr with 8 vac. Samething in first if i started to take off from a light knock would go up to .5 - 2.0.
Old 06-08-2008, 04:26 PM   #7 (permalink)
Elected Moderator
N0sferatU's Avatar
Member Number: 9266
what are you using to monitor knock with? Aeroforce gauge? If so what source? Knock Retard, LT Knock, ST Knock, Fuel Knock, etc? You should be on ST Knock.
2004 Dodge SRT-4
Stock Turbo, Stock Fuel System, Street Tires
60': 2.11
1/4mi: 13.29 @ 110.51mph
N0sferatU is offline   Reply With Quote
Old 06-08-2008, 10:09 PM   #8 (permalink)
The Shadow's Avatar
When I said you were running leaner, I didn't nec mean you where too lean. What I ment is if you were already seeing say 3kr@5-6000 with 11.0 A/F (this could be any # 10-12 A/F) and then you open your dump which IS going to lean you out, prob .3-.5 A/F so now your 11.0 just changed to 11.3-11.5 A/F your kr will increase.
Old 06-09-2008, 02:01 PM   #9 (permalink)
Member Number: 40273
Trader Rating: (21)
Same thing happened to me when I was stage 2 no toys and bolt ons. I dont think it has to do with his afr. I saw 10's with it opened or closed. Took it off and sold it. It was not catted.
S3Rh
Missing 04 Eblue as of 7/11/08.
98turboteg is offline   Reply With Quote
Old 06-09-2008, 04:17 PM   #10 (permalink)
Member Number: 9221
Trader Rating: (18)
I am using a scan gauge and watchin knock retard. I didnt know there are other ways to watch knock with it.......how do you switch between them?
Old 06-09-2008, 04:20 PM   #11 (permalink)
Member Number: 9221
Trader Rating: (18)
But that knock with the cutout closed is not consistant. One pull i could get no knock and while normal driving i can see .5-2kr. I understand what you are saying though. Shouldnt 11.3 AFR be safe though. I know when i was runnin the AFRs in the 10s it was the same way.
Old 06-09-2008, 04:20 PM   #12 (permalink)
Member Number: 9221
Trader Rating: (18)
When you sold it did your problems go away?
Old 06-09-2008, 04:27 PM   #13 (permalink)
Freaky's Avatar
Member Number: 47525
mine shows knock to with the dump open . but my a/f doesn't change . but i reading knock off the dtec fc/bc . i know i need a scan guage so until then i'm gonna leave the dump closed i think .
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is offline   Reply With Quote
Old 06-09-2008, 05:40 PM   #14 (permalink)
Member Number: 9221
Trader Rating: (18)
Yeah what the hell. I dont think changing the AFR .3-.5 is gogin to cause 6 counts of KR
Old 06-09-2008, 06:47 PM   #15 (permalink)
Freaky's Avatar
so i hear dtec knock can't be counted on. someone with more info please chime in . can i count on the dtec knock count ?
» Search Used Cars
Page generated in 0.29468 seconds with 11 queries
