Old 04-11-2006, 04:13 PM   #1 (permalink)
Member Number: 14729
Default help with wideband readings...
well first off ill try to get the most important things out in the open
50trim, 750's, return line, fuel pump, return like set at 44psi
right now i have a huge exhaust leak at the silly flex dumb tube, so im only running 13psi.
at 13psi, my a/f reads 12.2, or high 12's...
at idle its 14.7-15.00
can somone help me out here, it's the zeitronix wideband
DCR fully equiped t3/t4 60-1 hifi stage3 "dyno soon"
bolt on's
460hp 435tq @28psi
425hp 398tq @22 psi pump
fullybuilt 50trim = DEAD after 8k miles
immyz is offline   Reply With Quote
Old 04-11-2006, 04:26 PM   #2 (permalink)
bump, for some answers
Old 04-11-2006, 07:42 PM   #3 (permalink)
Klop's Avatar
Member Number: 39970
Is the exhaust leak before the O2 sensor? If so you will need to fix that for sure. It will cause false readings.
Klop is offline   Reply With Quote
Old 04-12-2006, 07:27 AM   #4 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
A/F at idle is fine. However at WOT you really should lower boost or richen thing up. What is your A/F towards redline?
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 04-12-2006, 09:07 PM   #5 (permalink)
Member Number: 27600
Trader Rating: (38)
Fix your exhaust leak asap and recheck your af's. You exhaust leak will suck in a little air which leans up your af's. Even if the exhuast leak it slightly behind the sensor it may still lean it up a little.
Mods= Lots of Goodies
a7594217 is offline   Reply With Quote
Old 04-12-2006, 09:25 PM   #6 (permalink)
Member Number: 40294
12:1 isnt that bad?? You guys much be used to PIG rich horriblely rich tunes or something... 12:1 on a boosted car is VERY ideal
My car is daily driven for over a year on 12:1 AFR's with 450whp on pump gas... I love makeing great power along with 27-30mpg... i dunno about you guys tho..
fix your exhaust leaks, but from what i see... nothing is that wrong w/ ur AFRs that i see.
Darton Sleeved 2.0L crvtec
Pauter rods w/ Arais 10:1's
B16A head w/ AEBS intake manifold
92 dx HB, 2400lbs w. driver
4/06
15psi w/ 25" M&H slicks
1/8 - 6.9 @ 105
1/4 - 11.3 @ 123
(w/ broke 4th gear... coastin )
10/05
11psi w/ BFG's
1/8 - 7.5 @98
1/4 - 11.5 @ 126
JDM_SRT-4 is offline   Reply With Quote
Old 04-12-2006, 09:55 PM   #7 (permalink)
Member Number: 27517
Sounds kinda lean for having 750's a return line and a pump on only 13PSI??
jeremy6 is offline   Reply With Quote
Old 04-14-2006, 06:19 PM   #8 (permalink)
Trader Rating: (37)
Yeah, I do agree but her also mentioned that 12.2 or higher. So I'm assuming that he could be saying 12.5/12.6/12.7/etc. On mine, the first inital punch is 12.2 as RPM rise it richens up to about 11.5
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.18143 seconds with 13 queries
