Old 06-16-2008, 07:48 PM   #1 (permalink)
Member Number: 41151
Default help with dtec
Hey guys how well do the Dtec work with the stock ecu or is it better to upgrade? I tried putting in dw stg 2 injectors and the car ran like shit in third and fourth gear so I put the stock injectors back in and now I dont know where to go from here can someone please help. Thanks in advance...
LIL V is offline   Reply With Quote
Old 06-16-2008, 10:23 PM   #2 (permalink)
Big Corey's Avatar
Member Number: 58459
Trader Rating: (33)
dtec works good easy to tune with also
AGP3147 ,QW BFMIC,Atp hard pipes,HKS bov,3 in maxfab dp without cat,greddy evo2 catback stage2,many other mods to come
FORSALE:Boomba STS & WTT:stage2 injectors for 650s
Big Corey is offline   Reply With Quote
Old 06-18-2008, 05:55 AM   #3 (permalink)
Member Number: 41073
You can do two things "E". You can get a S1 or maybe go a cheaper route which is getting a fuel pressure regulator and see what does for you. If Im wrong someone please correct me
srt-33030 is offline   Reply With Quote
Old 06-18-2008, 10:04 AM   #4 (permalink)
tamadx's Avatar
Member Number: 26290
Trader Rating: (18)
put the dw stage 2's back in and reset the comp.... You have any other way of monitoring fuel etc?
S3, WGA, Return Line, CAI, Turboback, BFMIC, 55mm TB, DTEC, Wideband, W/I, Scan Gauge, Ported Stuff
tamadx is offline   Reply With Quote
Old 06-18-2008, 07:35 PM   #5 (permalink)
So what you are saying is put the dw stg 2's back in and reset the comp and it should work even if it is a stock ecu?
Old 06-19-2008, 06:23 AM   #6 (permalink)
tamadx's Avatar
Trader Rating: (18)
Yeah i ran stage 2's with a stock ecu a lot of people run stock ecu with major upgrades.....it should work fine.
Old 06-19-2008, 08:00 AM   #7 (permalink)
Member Number: 59653
DTEC is nice and easy and ends up great for tuning
Click Here to Enter The site.
http://www.tuningneons.com
dtecneon is offline   Reply With Quote
Old 06-19-2008, 08:15 AM   #8 (permalink)
Was that S2 or DW S2? They are different fuel regulator readings right? I think DW S2 are rated at a higher fuel reading than S2.
Old 06-19-2008, 08:42 AM   #9 (permalink)
tamadx's Avatar
Trader Rating: (18)
Mopar stage 2's are 682cc at 58 psi the DW stage twos are 590cc or somewhere close at 45psi. so at 58 psi they should be around the same even though when i put my DW's in they gave me more fuel than the mopar stage 2's
Either way the car shouldnt be running like crap with just adding stage2's.....they are not large enough for these cars to cause problems like the 750's might
» Search Used Cars
Page generated in 0.22966 seconds with 11 queries
