Old 11-04-2009, 11:11 PM   #1 (permalink)
mikedero08's Avatar
Member Number: 71493
Default Harder to tune without stock solonoids?
Someone told me it would be very difficult to have a tune made for my car with a DSP unless I was running pcm controlled boost... I dont understand why that is. Would it be better to go back to solonoids?
Full rebuild in progress
mikedero08 is offline   Reply With Quote
Old 11-04-2009, 11:18 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
you dont have to
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 11-05-2009, 10:39 AM   #3 (permalink)
duster360's Avatar
Member Number: 45182
With a stock turbo, PCM boost control + stock wga works much better than a $150 wga off PCM control. Red and Green solenoids would be required.The PCM/DSP boost control is easy to adjust and has 0 PTB
If you've already spent the money on a aftermarket wga,,its your call but I strongly encourage you to give it a try. My APG wga has been off the car for several months.
duster360 is online now   Reply With Quote
Old 11-05-2009, 03:34 PM   #4 (permalink)
mikedero08's Avatar
How about for a 50 trim?
Old 11-05-2009, 03:45 PM   #5 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
It's very, very easy to tune without the solenoids. I am on a turbonetics WGA and I have 0 issues dialing in my tune. I have actually never HAD my solenoids. They were cut off
With a .50 trim, you really have no choice other than to be WGA controlled. A few have found out how to make big turbo PCM controlled, but you have to go to their shop and such...which long story short, you will be fine with a DSP in your scenario.
Quote: Originally Posted by KoldKill View Post
E1 is ethanol fuel (corn based) you need mucho larger injectors and a tune (I think?) to run it...
Adionik is online now   Reply With Quote
Old 11-05-2009, 04:06 PM   #6 (permalink)
mikedero08's Avatar
awesome. i was slightly worried.
Old 11-05-2009, 04:27 PM   #7 (permalink)
Floner's Avatar
Member Number: 26683
+1 here for non pcm controlled with 50.T or with any turbo for that matter. Personally I like being able to control my own boost. It's not hard and easier to dial in in my opinion.
This Place For Rent!
Floner is offline   Reply With Quote
Old 11-05-2009, 05:22 PM   #8 (permalink)
duster360's Avatar
Yeah that's a whole different story.
Tuning an External wga would require CMR or SCT PrP software. Many guys have done it and it works very well, but it takes quite a bit of trial and error to retune the PCM for the different wga/turbo.
Old 11-05-2009, 06:08 PM   #9 (permalink)
Floner's Avatar
I use an AFC for fuel and boost controller for the wasegate, no vaccuum lines are hooked up to the pcm solenoid, and havent been for over 50k. Not that complicated.
Old 11-06-2009, 07:31 AM   #10 (permalink)
duster360's Avatar
I didn't know anyone was still using pos piggy-backs, since they're pretty much obsolete.
You need to upgrade to 2008 and get a DSP.
Old 11-06-2009, 07:50 AM   #11 (permalink)
lyncoo's Avatar
Trader Rating: (92)
x2 being able to control timing some what is great.
on a big turbo you might loose alittle bit of spool by not having a good mbc
Old 11-07-2009, 04:45 PM   #12 (permalink)
mikedero08's Avatar
i have a hallman with a ceramic ball. idk anything about it. should i get a better one?
Old 11-07-2009, 04:47 PM   #13 (permalink)
Floner's Avatar
Not to worry ill be getting a dsp in the near future, just have to wait till i do my clutch upgrade first. That and Christmas is right around the corner so funds will be alloted to other things.
Old 11-07-2009, 07:14 PM   #14 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
I never used pcm (non-dsp) to control boost and never had a problem even with just WG controled
Page generated in 0.15568 seconds with 13 queries
