Going to be tuning the emanage Thursday (08/12), need some hints...
Mods are:
Greddy e-manage
Greddy e-01
TurboXS WGA
JLM 3" Catless DP (with a cutout)
BDJ's 3" CAI
Stage 1
Spearco FMIC
Right now the e-manage is controlling the map clamp portion (Boost Limiter Cut) and fueling (Add Injector Map) in the parameters. Boost is, of course, being controlled by the e-01.
Right now I am boosting a steady 18psi to redline and using the stock map sensor to read boost. I plan on tuning for some C16 and have the optional connection that allows the e-manage to read from the e-01's 3 bar map sensor.
My question is, how will reading off the 3 bar sensor affect what needs to be inputed in the e-manage.
For example, right now my "Add Injector Map" looks like this:
from 4.5volts on it is set to 25.0. This is from 50 all the way to 6500 rpms. If I switch to the different map sensor with the 25.0 need to become a 10.0, 15.0, 40.0, etc etc?
I am assuming the map clamp portion (Boost Limiter Cut) will remain unchanged. Right now it is set to 4.50 volts from 50 to 8000 rpms.
Does anyone have similar mods with an e-manage and tuned their car yet?
Thanks!
Jim
11.6@125
