Old 07-22-2004, 07:37 PM   #31 (permalink)
silverscooby's Avatar
Member Number: 1525
The map sensor that comes with the E-01 is a 3 bar. Problem is, the e-manage uses the stock map sensor to tune unless you purchase the optional link from the e-01 to the e-manage for the 3 bar sensor. This allows the e-manage to use the e-01's map sensor rather than the stock one.
You need this in order to run over 18psi. Most places that carry Greddy stuff can get it for you. It's called "PRofec E-01 Pressure Sensor Harness" Should be $20-$25.
11.6@125
silverscooby is offline   Reply With Quote
Old 07-22-2004, 08:43 PM   #32 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
ok..now what hector said makes more sense...and it saves $95
Thanks
C
Damn it, Have a nice day...
11.9@121 Bithlo
SRT-4 Neon is offline   Reply With Quote
Old 07-22-2004, 10:18 PM   #33 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
Thanks
C
yes what scooby said, instead of going with an outboard MAP sensor for an additional $125 you use the Pressure sensor that comes with the Profec E01 to get your pressure readings. It doubles up as a MAP sensor for the Emanage but only if connected to the E01 with the extra harness.
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 07-22-2004, 10:54 PM   #34 (permalink)
BlueSRT404's Avatar
Member Number: 8099
Thanks Silverscooby and NIVO88T!!
I did buy the emanage, injector harness, and the pressure sensor harness today from Peformance Autowerks (their local for me) one of our supporting vendors too. I wasnt sure if I needed that extra pressure sensor harness, but Im glad I got it! They had to order the e-o1 though. Now I just need that and a wideband controller and Im all set. Oh, and my AGP turbo kit (Im counting the days)
~Eric
04' Blue 50trim SRT-4 (sold)
05' Black Crossfire SRT-6
05' Silver Ram Quad SRT-10
96' Neon SOHC coupe (runs 14.9's lol)
BlueSRT404 is offline   Reply With Quote
Old 07-24-2004, 12:52 AM   #35 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
i finally got all the pieces I need (save a WB controller). I hope to tackle this one in the next couple of days...
What I need to do now is add the wires to the emanage harness for the injector harness.
C
Old 08-10-2004, 01:29 PM   #36 (permalink)
Member Number: 180
so are all you guys using the TPS or are you doing the AFC trick of using MAP voltage for the TPS in signal to the emanage?
i haven't got mine yet or looked at the software but the impression i'm getting is you get a second map in the software to use when you have the pressure sensor installed, thereby making the MAP/TPS trick unnecessary
NeonWaSp is offline   Reply With Quote
Old 08-11-2004, 12:03 PM   #37 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
I followed the instructions somewhere above in this thread...works like a charm. I've left everything alone for now as my wideband isn't in yet, but so far no troubles with monitoring the engine.
C
Old 08-11-2004, 12:13 PM   #38 (permalink)
Member Number: 11555
Alot of people are just clamping the map and adding fuel after 15 psi or so..
ToFu is offline   Reply With Quote
Old 08-25-2004, 12:22 PM   #39 (permalink)
Member Number: 4635
Would installing an e-manage and e-01 over-ride the rpm limiter? Or can that only be done with a stand alone?
Don't think... react.
soybuff is offline   Reply With Quote
Old 08-25-2004, 12:43 PM   #40 (permalink)
NIVO88T's Avatar
Member Number: 1109
you're going to be looking into a stage 2 PCM or Stand Alone system to get higher than stock rpm limit.
Old 08-30-2004, 10:17 PM   #41 (permalink)
SRToc Member
Member Number: 13708
does one mess with timing with a E01 and emanage? Or does that get left alone and only Real adjustment is boost and fuel??
robertk is offline   Reply With Quote
Old 08-31-2004, 11:13 AM   #42 (permalink)
SRT-4 Neon's Avatar
Member Number: 1573
right now there is no ability to control timing directly with the emanage. What you do is play with the map clamp voltage to set the timing.
C
Old 09-24-2004, 03:26 PM   #43 (permalink)
Member Number: 12706
Quick question: If I set up my emanage exactly as above, does this mean that it will be running as if it werent even there? (ie. no additional fuel, timing, etc) The car is stock and I would just like to have my emanage installed and running before I started doing any mods.
SRT42B is offline   Reply With Quote
Old 09-24-2004, 05:11 PM   #44 (permalink)
Member Number: 180
yeah as long as all the tables are zeroed out and there's no injector correction it should be as if it wasn't there.
Old 09-24-2004, 05:28 PM   #45 (permalink)
Good deal. Thanks.
