Old 06-30-2004, 10:02 AM   #1 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
E-Manage Discussion/Help Thread
I just figured since there are some Greddy E-Manage owners out there and many are new to it, this thread might be useful for the E-manage Veteran users to help others. And keep the load of Hector from Exhaust Depot.
help with:
  • Install
  • set up
  • Wiring
  • Maps
A fully configured Emanage can now be bought from Exhaust Depot
Please try to keep this thread "E-Manage" only.
__________________________________________________ __________
E-Manage Mini Wiring How To by SY04SRT4
It's a car hackers paradise with pirated copies of the support tool available, homade chip cables, intracate circuit board schematics etc... It's really a sweet product that I definitely wish would become more widely used!
HERE it is in MS Word .doc format
http://home.comcast.net/~pbateman/emanage1_0.doc
And in text..
E-Manage Mini Config/Wiring How To
By: Chad - SY04SRT4
EM: chad5160@excite.com
AIM: chad5160
Inside the E-Manage
The E-Manage is such a “universal� unit that there is a little bit of pre-config that has to be done before you mount the main control box or hook up any wires. There are some jumpers inside that need to be checked/changed and the 3 POTentiometers under the front panel that need to be set. Always set the 5 front Airflow Adjust POTS to 0 and do all the adjustment with a laptop or the E-01. You will NOT get accurate or repeatable results using them!
To open the unit remove the four screws from the bottom and the 4 hex head screws from the front cover. The front cover is the side with the USB jack and the 5 exposed “Airflow Adjust� POTs. You DO NOT need to remove the back cover. After the front cover is off slide the board out gently. This is where we want to check the jumpers. All NEW E-Manages are shipped with these settings in the correct default (no V-Tec) values, but I would double check. The Jumpers need to be set like this:
Jumper - Setting
JP1 - 1-2
JP2 - 1-2
JP3 - 1-2
JP4 - OPEN
JP5 - OPEN
JP6 - OPEN
JP7 - 1-2
At this point you can slide the board back in and install the 4 bottom screws to hold it in place. Leave the cover off for now. The front that is now exposed is where the 3 POTs are for the Airflow Sensor type. These are VERY important so double check. The POTs we are worried about are 1-3 starting from the left to right. The far right POTs 5&6 don’t matter because we just disabled V-Tec with the Jumpers!
POT - Setting
1 - 2
2 - 4
3 - 1
If these are correct the Airflow Sensor should read out as TY_PR_2. You’ll see that either on the laptop Support Software or E-01 once it’s all done.
The Main E-Manage Wiring
The basic wiring on the E-Manage unit consists of:
Power
Ground
Airflow In (MAP)
Airflow Out (MAP)
Tach/RPM
Throttle Position (TP)
The wiring should be tapped off the main PCM harnesses. You will only need to attack harness C1 (Black) and C2 (Orange). Always have a copy of your E-Manage manual and PCM diagrams handy!! Always check the wires by pin location. Some wire colorings vary slightly through production. It’s always good to double check!
Here is how the wiring corresponds:
E-Manage - PCM Harness Location
Power [Red] - C1 - 11 - [Dark Blue/Red] This is a RUN-START +12v
Ground [Black] - C1 - 9 - [Black/White] Good ground, some people go straight to the battery.
Airflow In [White] - C2 - 23 - [Dark Green/Red] This is the Input of the MAP signal. This wire needs to be cut and the end going to the CAR connected here. VERY IMPORTANT
Airflow Out [Green] - C2 - 23 - [Dark Green/Red] This is the Output of the
MAP signal. This wire needs to be cut and the end going to the PCM connected here. VERY IMPORTANT
Tach/RPM [Brown] - Needs to be connected to a “tach� source such as an MSD tach driver.
Throttle Position [Gray] - C2 - 21 - [Orange/Dark Blue stripe] Throttle Position
Injector Harness
Make sure you get a Greddy brand harness and not some knockoff or the colors will be off! This "harness" is a bunch of wires you connect in to the existing main E-Manage harness. They come with the proper pins on them and just click in to the main connector. The E-Manage is even available with the harness new as well.
The wiring needed on the injector harness consists of:
Injector Channel 1 [Blue/Red] - C2 – 14 – [White/Dark Blue] Injector Control 1
Injector Channel 2 [Orange/Red] - C2 – 13 – [Tan] Injector Control 2
Injector Channel 3 [Yellow/Red] - C2 – 12 – [Yellow/White] Injector Control 3
Injector Channel 4 [Purple/Red] - C2 – 11 – [Light Blue/Brown] Injector Control 4
Ground [Black/Red] - C1 - 9 - [Black/White] Good ground, some people go straight to the battery.
Ignition Harness
Yes, it can work, but needs modification! Just don’t hook it up. You will fry the IC for the Ignition Control. If you have the harness, tape the wires and stay tuned for more info!
__________________________________________________ _________________
Mopar Injector Conversions
Below are the Mopar injector sizing then converted to 43.5psi of fuel pressure. This is useful once you go with larger injectors and need the conversion numbers to scale down the new larger injectors (530cc, 650cc, 750cc etc)
SQRT of New Pressure/Old Pressure = Value * OLD_FLOW_RATE
Convert injector rating @ 58 psi to 43.5 psi:
SQRT of 43.5/58 = .866025 * INJECTOR_FLOW_RATE
Stock 2003 SRT4 (524cc/min @ 58# * .866025 = 454cc/min @ 43.5 psi)
Stage 1/2004 SRT4 (577cc/min @ 58# * .866025 = 500cc/min @ 43.5 psi)
Stage 2 (682cc/min @ 58# * .866025 = 591cc/min @ 43.5 psi)
Tach adapter wiring - by E.D.
MSD 8913 Tach Adapter/Driver
Make sure you install the tach adapter in the area shown in the pic and not at the PCM connector as you may experience signal loss.
Cut greenwire with orange stripe on the coil. This is the VCC for the coil. Attach the red with green stripe TOWARDS the COIL. Attach the solid red wire towards the POWER DISTRIBUTION.
The black is ground, I like to attach it to the battery cable. The grey is your tach signal. The grey wire will connect to the AFC/SAFCII green wire.
You can tie wrap the unit to the hoses and vacuum lines on the side of the battery tray.
If you dont have a soldering iron, then you should not be purchasing this item.
~Exhaust Depot
Some E-Manage/e-01 tuning tips by: reed32: Posted 01-08-2006 -- Thanks reed!
1) The Eo1/emanage allows you to see three features on a graph,meter, bar graph tec.. The three features you want viewable is the boost, throttle, a/f reading from a wideband of course.
2) Setting Boost:
There also three features when setting the boost.
a) set feature: is the actual boost you are running and is in percents. its al based on the turbos flow so it will vary from turbo to turbo. start around
48% which will be around 17-19psi and work your way from there.
b)Gain feature:
gain feature is the bleed off the soleniod which gives you a good torque curve and a faster spool. the gain must be within 3-7% off the set but normal people go 3-5% from the set.
c) The Start feature:
The start feature has to be 2 points off the actual boost. Example. you want 18psi of boost so the start would be set at 16psi. this is for the wastegate to open up. if you have the start to low then you will cause over boost (spike). another example:
low boost 18psi
set 48%
gain 45%
start 16psi
If you adjust your gain to much then it will throw off your set value(boost) so you might have to increase or lower the set.
3)Map clamp:
is in the boost limiter (d) emanage but you have to set under set up in the e01. The higher the map clamp (4.4vlts for stage 1/0) makes the car richer. The lower the map clamp (4.0-4.2 stage 1/0) leans the car out. watch out though, if you pull to much fuel for that map voltage then timing issues will occur. The neat thing about the e01 is that you can set different map clamps throughout the curve at certain rpms.
example: 4.0vlts from 3500-4500rpms
4.4 vlts from 4500-6200 rpms etc..
4)E01 boost safty feature
go to and click on set up in the e01, then click on warning. It has a boost limiter you click on with the e01 button and scroll clockwise vise versa to move up and down the boost. The boost you set it at will not allow the turbo to boost beyond that boost mark. if it does there a limiter underneath the boost limiter and it will cut your over boost down in a percent for you (ive been told to set this at -20%).
5) tunning: airflow adjustment map
From what informatin ive been given you want the a/f to be starting at 11.8 dropping to 11.6 at redline for a safe tune. In the airflow map you want to start full throttle at 70%-100%(left colum of the chart) for each columnand row. To pull fuel just click on the e01 button,twist the button left to subtract fuel and right to add fuel. Now lets say you want to pull 2% of fuel @4k, click menu,select emanage, click on airflow adjustment map and go to 4k and subtract 2%from 70%-100% throttle column.
you can highlight serveral rows and columns but i don't know that yet. Pull fuel little at a time to be on the safe side.
6) Saving fuel maps
The e01 allows you to save up to three fuel maps onto the sim card. look under the emanage in the menu. find the load/save.
click save and then go down to one, where it says either Data1,2,3 or Map 1,2,3. Click one of the three fuel maps and go down to press okay. so you can make a summer map, winter map and a race gas map whatever you like them to be. to load each map you just click on load and press okay.
7) the fun part: record/playback mode
a) to record : press the down arrow on the e01 controller. look in the lower right corner to see if the timer started.
b) to stop recording: once you've completed the run press the down arrow again.
c)to playback: pull over [img]http://www.**********.com/phpBB2/images/smiles/biggrin.gif[/img] . hold the e01 button down for 3-5 seconds or until the play feature is flashing at the top of the e01 screen.
d) rotate the controller button to scroll every rpm,boost,afr,map voltage,etc..
e) how to look at certain cells during playback mode.
simply hit the menu button twice, go to the airflow adjustment map inside the emanage and look for a box not highlighted. Thats the cell you are at, at that part of the fuel curve. hit enter to highlight the box and subtract /ADD FUEL.
f) During playback mode you can change what features you want to monitor during you run. just hit the menu button once and then press the down arrow to highlight a feature you want to change. once again, move the e01 button around to scroll up and down the list of options. once you found the feature you want hit enter. to play the run over with the new feature hit enter (e01 button) and it will play it back again. notice you can control how fast you want it to play back meaning you can do it rpm by rpm as slow as you want by twisting the e01 button.
Old 07-01-2004, 10:09 AM   #2 (permalink)
NIVO88T's Avatar
Member Number: 1109
Default Silverscooby post
Silverscooby posted this on 6/24/04. Just adding it to the thread about Emanage to help jump start it.
__________________________________________________ _______________________
Installed the e-01 a couple weeks ago and it has worked great. Finally got the time to hook up the emanage over this past weekend. Not too bad with Hector's instructions and help, just took a while to solder everything together.
The car started fine, didnt throw any error codes or check engine lights. The "Active" LED was a solid green on the e-manage itself which is good. Only thing I was missing was a USB cable to run from the e-01 to the e-manage.
So I picked one up yesterday and today connected it from the e-01 to the e-manage. Start the car up and I get a screen on the e-01 display asking if I want to update my e-manage. I click yes and get a transmission error. Okay.... restart the car. This time I click no. Now it asks me if I want to update the e-01 and the e-01 display. I click no.
So the e-01 display is doing it's thing, but I notice I can't get TPS to display. It's getting no reading from the e-manage like it should. It just reads 0%. While talking on the phone with Hector (trying to get this thing sorted out) we notice the maps are all zero'd out as well. Like they were erased or something. No problem, Hector walked me through them and we re-entered the map clamp and the fuel portion.
I saved the new maps to Data3 on the e-01. I then tried to export them to the e-manage. Communication error. I tried to import ... communication error. To add to all this, I now have a check engine light and the car stalls out whenever I start it up.
Also, my e-manage "Active" led is blinking green/yellow/red. I dont get it, the install is correct. That was verified by the solid green active led on the e-manage up to this point. All I did was connect the usb cable and now all hell broke loose.
I need some help, any suggestions?
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 07-05-2004, 03:37 PM   #3 (permalink)
FrontMounted's Avatar
Member Number: 9995
Trader Rating: (10)
So can anyone explain the problem? I was thinking of getting an emanage too but not if it's gonna be a big hassle.
"straight clownin" This is not Photoshop
It's for someone considering an Acura RSX, but actually wants some power --Road & Track
FrontMounted is offline   Reply With Quote
Old 07-05-2004, 03:47 PM   #4 (permalink)
Exhaust Depot's Avatar
Member Number: 143
Trader Rating: (98)
Its not a big hassle. The unit scooby has was a used unit which he sent me to setup for him, so there might be an issue with it. There was a problems with the eo1 communicating with the emanage. I currently have it back and will see if its damaged or not.
Exhaust Depot is offline   Reply With Quote
Old 07-05-2004, 08:26 PM   #5 (permalink)
silverscooby's Avatar
Member Number: 1525
I appreciate your help on this Hector. The unit was not used. It was new and in the box. I had a friend who was going to use it on his 350z but decided to go another route. It seemed like the two units were trying to run different versions of the software. Hopefully Hector can work his magic and fix the problem.
I am looking to get it tuned and hit the dyno on 93 and C16. We'll see what the stock turbo can do with some engine management.
11.6@125
silverscooby is offline   Reply With Quote
Old 07-05-2004, 11:29 PM   #6 (permalink)
NIVO88T's Avatar
Member Number: 1109
It shouldn't be too hard to install this yourself as long as you have access to a soldering iron.
Old 07-05-2004, 11:35 PM   #7 (permalink)
Member Number: 143
Trader Rating: (98)
scooby, get my pm?
Old 07-06-2004, 01:33 AM   #8 (permalink)
SY04SRT4's Avatar
Member Number: 3903
Check the USB cable...I have seen them go bad!
What SW version on the E-Manage? 1.39 is the latest.
I can post some very useful info here. I'll work up a how to. I don't think it needs to be step by step. Anyone doing an E-Manage on their own should at least understand what there doing. It does make it a hell of a lot easier if you know the 3 POT settings and some wiring basics. I wish I did on my first SRT install. It would have been a hell of a lot easier the the proven trial and error process. I have some pics too. I have tons of pics of a recent E-01 install I can work up to. I am all about sharing knowledge for free.
Isn't that what these "type" of forums are intended for anyways?
chad5160@excite.com
2004 SRT-4
1999 SVT Contour
1979 K10 Chevy Crawler
1970 Mercury Cougar - Currently under KNIFE!
Buy My Mopar Coilovers!!!
SY04SRT4 is offline   Reply With Quote
Old 07-06-2004, 01:49 AM   #9 (permalink)
manny z's Avatar
Member Number: 759
Trader Rating: (18)
Default e manage-eo1 install.
If you are in the market for either one of these products, and are going to install them yourselfs, i would really bo on the lookout for his how to. I personally know of 2 cars that he has done installs on. And both of them came out kick ass. I am planning on getting an eo1 soon, and syo and me will be installing it in my car.
One more thing that I have to mention, you do not have to buy anything from him, or have to be from Cali, or be a loyal follower. He will give some good advice just because he know what the hell he is doing. And would want to help someone out.
manny z is offline   Reply With Quote
Old 07-06-2004, 03:25 AM   #10 (permalink)
SY04SRT4's Avatar
Member Number: 3903
Default E-Manage Mini Wiring How To
I will write so much more... I am just sooo tired and have to work sooo early!
I can do step by step if needed. I have lots of pictures too and some great links to E-Manage help! Thats the great thing about E-Manage...It's "Universal"!!!
And in text..
By: Chad - SY04SRT4 EM: chad5160@excite.com AIM: chad5160
Inside the E-Manage
The E-Manage is such a “universal” unit that there is a little bit of pre-config that has to be done before you mount the main control box or hook up any wires. There are some jumpers inside that need to be checked/changed and the 3 POTentiometers under the front panel that need to be set. Always set the 5 front Airflow Adjust POTS to 0 and do all the adjustment with a laptop or the E-01. You will NOT get accurate or repeatable results using them!
To open the unit remove the four screws from the bottom and the 4 hex head screws from the front cover. The front cover is the side with the USB jack and the 5 exposed “Airflow Adjust” POTs. You DO NOT need to remove the back cover. After the front cover is off slide the board out gently. This is where we want to check the jumpers. All NEW E-Manages are shipped with these settings in the correct default (no V-Tec) values, but I would double check. The Jumpers need to be set like this:
Jumper - Setting
JP1 - 1-2
JP2 - 1-2
JP3 - 1-2
JP4 - OPEN
JP5 - OPEN
JP6 - OPEN
JP7 - 1-2
POT - Setting
1 - 2
2 - 4
3 - 1
Power
Ground
Airflow In (MAP)
Airflow Out (MAP)
Tach/RPM
Airflow Out [Green] - C2 - 23 - [Dark Green/Red] This is the Output of the MAP signal. This wire needs to be cut and the end going to the PCM connected here. VERY IMPORTANT
Tach/RPM [Brown] - Needs to be connected to a “tach” source such as an MSD tach driver.
Throttle Position [Gray] - C2 - 21 - [Dark Blue/Orange] Throttle Position
Injector Harness
Ignition Harness
Old 07-06-2004, 05:28 AM   #11 (permalink)
nastyblacksrt's Avatar
Member Number: 2683
ED, i think you should list in this thread to your potential customers(me!) if you have preset maps which you probably do.
S1+ WGA+ BC
S1+FPR+Bigger turbo
S1+FPR
S2
S2+bigger turbo
S2+FPR+bigger turbo
(i think thats all the choices)
waiting till August first till i start doing business with you hector, strapped for money right now.
nastyblacksrt is offline   Reply With Quote
Old 07-06-2004, 05:30 AM   #12 (permalink)
Member Number: 2683
SY04SRT, Its not a necessity to install the injector harness, right? all you should need to control fuel are those six wires.
Old 07-06-2004, 08:16 AM   #13 (permalink)
Member Number: 9995
Trader Rating: (10)
S1+ WGA+ BC
S1+FPR+Bigger turbo
S1+FPR
S2
S2+bigger turbo
S2+FPR+bigger turbo
What about Stage 0 PCM plus bigger turbo, injectors, pump, etc
Old 07-06-2004, 08:20 AM   #14 (permalink)
Member Number: 9995
Trader Rating: (10)
Where can you get the pirated support tool? What all is included with the support tool? I know it's for hooking up emanage to your laptop and that's what I will do since I do not have an e01.
Old 07-06-2004, 09:19 PM   #15 (permalink)
Member Number: 1525
It's a brand new cable, but I'll buy a new one just to make sure. What baffles me is why the emanage started blinking red/yellow/green. It also seemed like it wasnt working at all because it started throwing map sensor malfunction codes and stalling out. When I jumped the green and white wires together upon taking the emanage out, the map sensor codes went away.
As far as the version, I do not remember.
Hector, I did get your pm.
» Network Links
