Old 11-10-2007, 04:32 PM   #466 (permalink)
dhinez's Avatar
Member Number: 51098
Trader Rating: (40)
Quote: Originally Posted by Beeznut02neon
Okay guys Im in the process of installing my emanage and have come to a problem, Well I am hooking up the Injector control#1 its the Withe/blue on the pcm to the blue/red. well the problem is that there is two of them there is a darker blue and a lighter blue which one do I connect to?
i would like to know.
Quote: Originally Posted by srtowner View Post
I knew one guy that was running a Treadstone kit. Unfortunatly he did not have it long before totaling his car.
Quote: Originally Posted by uberingram View Post
The car committed suicide.
dhinez is offline   Reply With Quote
Old 11-18-2007, 04:46 PM   #467 (permalink)
05redSrtfour's Avatar
Member Number: 54938
does the e-manage show your timing and kr? what are some number i should look for being safe running 22psi with DP w/i?
12.88 @ 94 1.80 60ft
Stage 1, JMB Ultimate CAI, B&B TBE, AGP Hardpipes w/Hks BOV, AGP upgraded WGA, 62mm TB. MSD Coil Pack, Pulstar Plugs. Coolingmist Direct Port meth inj, Tein S-techs, AGP Race FMIC, AEM Truboost, AEM wideband, M&H Slicks, 180T-stat **Not Added Yet** Fuel Pump, Rewire, Bottleneck, ., , FBM Ported/ Ceramic Exhaust Manifold, Maxxfab 3" 02 Housing. Ported Intake Manifold
05redSrtfour is offline   Reply With Quote
Old 12-12-2007, 09:51 PM   #468 (permalink)
Member Number: 55724
Trader Rating: (13)
i have a few q's refrencing the e manage...
1) the staged ecu's take away certin CEL's. (partial throttle overboost, o2 sensor, etc.)
does the e-manage remove these also?
2) how hard is the install on a scale from 1-10?
3) cost effectiveness... emanage vs stage 1 ecu/AFC-neo
4) reliability. i drive my car everyday, and i have a 3 yo son. i cant be stranded anywhere...
5)and im stock(plus intake, exhaust, mm, tranny m, booger bushings) what gain can i expect with a proper tune?(i have an agp wg, but will intall w/ ecu)
thanks.
my ps3 id is silverhkswrx.
friend request me, im always on CoD4!
rustyknuckles is offline   Reply With Quote
Old 12-16-2007, 10:16 PM   #469 (permalink)
Trader Rating: (13)
anyone?
Old 12-19-2007, 12:21 PM   #470 (permalink)
BlackSRT-4U's Avatar
Member Number: 890
Trader Rating: (29)
thanks.
does the e-manage remove these also?No it wont take away any CEL's..
2) how hard is the install on a scale from 1-10? Not hard .. just time consuming.. I would say an 8
3) cost effectiveness... emanage vs stage 1 ecu/AFC-neo It all depends on what you are looking for, and what will be in the Future for your car.. Big turbo, ect...
4) reliability. i drive my car everyday, and i have a 3 yo son. i cant be stranded anywhere... If installed correctly.. you wont have any problems what so ever...
5)and im stock(plus intake, exhaust, mm, tranny m, booger bushings) what gain can i expect with a proper tune?(i have an agp wg, but will intall w/ ecu) Gains are minimal to the eyes with the mods you have.. you'll provably see about 5-10whp gain throught the power band.. minimal power changes but you'll fell it.. since you'll be bringing up the boost.. thats where you'll notice the diference.
Hope this helps...
BlackSRT-4U is offline   Reply With Quote
Old 01-30-2008, 05:34 PM   #471 (permalink)
DJ Jonny B's Avatar
Member Number: 43488
can anyone help....i have the hahn 20G and portfueler and i just picked up an emanage...i already have the e-01 and i know i will be connecting the emanage to it but i was wondering if anyone has any suggestions for installing/setup for the emanage...ie will i be useing the injector harness or not seeing how i already have a duel fuelrail and im running a set of stock injectors and a set of rc650s and any suggestions on how to set up the emanage with the right injector/ turbo settings .....im also having problems connecting my PC to it...i DL all the software from yahoo group and did everything it said to and i still can't connect... i bought a $50 transfer cable and still nothing, any info would be greatly appreciated very much
i have a bunch of do-hickies on my car
DJ Jonny B is offline   Reply With Quote
Old 02-15-2008, 12:03 AM   #472 (permalink)
srthizz's Avatar
Member Number: 44799
hey fellas, im about to install the emanage ultimate on my car pretty soon. ive been reading about the wiring diagrams and asking people in different forums for the diagram. now my question is, do i have to put the tps wire(grey) from the emanage to the green(map) wire for better accurate reading? or putting it the way it was originaly diagram which to be connected to orange and dark blue strip?
SRTHIZZ
AGP WGA, V5 Needswing Downpipe, Motor Mount Insets,
srthizz is offline   Reply With Quote
Old 06-01-2008, 11:22 AM   #473 (permalink)
jasonparson's Avatar
Member Number: 63747
*BUMP* to revive a really long and really interesting thread
I recently bought a used '04 with bolt ons. Car runs somewhat querky but it feels fast. No extra monitoring equipment on this car what so ever. I did find a e-manage under the carpet next to the clutch pedal The green light is on, the dials are all centered on the outside, but havent looked on the inside the the other switched mentioned in the instructions (which I did find the manual on the greddy web site. I have no laptop and no support cable and software. I have no idea what its doing as far as piggy backing the fuel. I have been tempted to shut the car off, disconnect and maybe even reset the dtc's and adaptive memory. Then go for a test drive and see if it changes. I would like to sell it and go for the ptp unit. I like the idea of the autotune and not personally owning any ptp products, I would suspect that its good stuff. I am no newb to working on cars (Ase master cert. auto technician) but I dont think unplugging it would make a dang bit of difference. But you guys are the expert on this unit so I want yall's opinions. Thanks so much in advance
100KB file size limit
jasonparson is online now   Reply With Quote
Old 06-08-2008, 06:16 PM   #474 (permalink)
909Sxt's Avatar
Member Number: 35993
Trader Rating: (13)
well guys Im new to the Emanage/e01 club, I was wondering the guys with the external gates what seting do you have the boost controller at auto or manuel? also the highest amount of boost I was able to achieve on my turbo was 30lbs, but I can only get 28lbs with the boost controller then boost falls off, any advice?
909Sxt is offline   Reply With Quote
Old 06-22-2008, 08:06 PM   #475 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Alright guys I seem to have some issues with my idle A/F ratios. For the last couple months I've been in the low 13s and mid 13s. It was doable. Now I am at low 12s, I'm saying, 12.0-12.3. It smells like pure fuel idling. Cruise AFR and WOT AFR are in tune and good to go. I can't seem to figure out how to adjust the AFR at idle to lean it up a bit. I've tried messing with the airflow tables but it doesn't seem to have any affect. Any help is appreciated.
Old 06-23-2008, 04:02 PM   #476 (permalink)
CrEaTrE's Avatar
Messed with the airflow tables 500-1500 RPMS, put them all to -50 and AFR at idle are 13.5-14.2. Won't let me take away any more fuel I guess. Anyway to get her up to 14.7? At least now it doesn't smell like pure fuel.
Old 07-08-2008, 11:26 AM   #477 (permalink)
Noid's Avatar
Member Number: 9278
Need help with emanage install. I have an E.D. Emanage unit that I bought 3rd hand but never installed. The wiring harness seems to match the install instructions here, except for the injector connections. Does anyone have a picture of an emanage harness or can tell me the position of the injector connections based on the positions.
I sent a PM to E.D. but no help there. They told me that the colors were changed so that he can determine if a unit came from them but they don't have the info available anymore.
A close up pic of the harness would help if anyone has it.
Noid is offline   Reply With Quote
Old 07-15-2008, 10:42 PM   #478 (permalink)
909Sxt's Avatar
Trader Rating: (13)
I have an emergency questions guys, I have a grey wire thats tapped into my ignition coil, does anyone know if thats the tach adapter, if not, I think the e-manage was installed on my car with out the tach adapter also, is the software update worth geting?
stock and proud of it
Old 07-24-2008, 09:18 PM   #479 (permalink)
turbovybez's Avatar
Member Number: 54273
Does anyone in the south florida area have the cable that goes from the emanage to the laptop. I have been asking for the last two weeks on floridasrtoc.com and it doesnt seem like anyone has one over there. Just wondering, i would like to borrow it if at all possible to tune a homeboys car or if someone is selling one i would be very interested in purchasing it.
Power: 291HP, 318TRQ
Mods: Intake, Exhaust, Wastegate, SAFC II......custom street tune. THATS IT I SWEAR!!!!! Stage 0 holdin it down
MY Baby died on November 18, 2007
You will always be missed!!!!!!!!
turbovybez is offline   Reply With Quote
