Old 06-28-2008, 10:34 AM   #1 (permalink)
Member Number: 52255
Default dtec tps jumps around at WOT
just wondering if anyone else has had a problem with the tps on the dtec jumping around between about 92-100 percent while the car is at WOT. I think that is part of the reason why my boost is a little jumpy. im going to check tonight the tps on the scangauge to the tps on the dtec at WOT to verify its not just the actuall sensor. any ideas on what it is would be appreciated. im thinking it might just be a wire has come loose but havent been able to unwrap the bundle at the ecu yet. also i believe when i hooked it up a year ago i hooked it up to the map in wire that has been suggested. i never really had to big of a prob with the jump either until i went to the bigger turbo and ecu reflash.
2005 SRT4
AGP stg3 Delta(44lb)
Bolt on Maxed, Meth, TCS, Suspension, etc.
ofallonsrt4 is offline   Reply With Quote
Page generated in 0.11199 seconds with 11 queries
