I doubt you will get too many people to respond for two reasons. Each car is a little different and whats good for one car may be too lean for another. The second thing is I doubt too many people have the Dtec with just STG 2. That being said I have pretty much the same setup as you
What I did was slowly pull fuel a little at a time. I only pulled fuel at 90% and 100% TPS to start. I would do a third gear pull from aprox 3300rpm to red line and watch the AFR's. I did notice that I had to tune for the spike meaning my map looked like the following..
.......... 90% 100%
3000rpm -6.0 -6.0
3500rpm -6.5 -6.5
4000rpm -6.8 -6.8
4500rpm -7.0 -7.0
5000rpm -7.0 -7.0
5500rpm -6.5 -6.5
6000rpm -6.0 -6.0
6500rpm -6.0 -6.0
This is not the exact map but close. This was a very conservative tune that kept the AFR's at 10.8 for my car. I am waiting for my scangauge to arrive before I pull anymore fuel. I want to stress that this was on my car and suggest that you pull small amounts of fuel at a time. What I did to speed up the process was to program three different maps at a time. Each one would pull just a little more fuel. I would hit the road and if the first map showed safe AFR's I would load the next and so on. Good luck!
