Old 01-22-2008, 12:42 PM   #61 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Quote: Originally Posted by Pedro View Post
ok, so say just for shitts and giggles i set the 25% side to -5%. will it pull 5% of fuel from anything lower than 25% boost/throttle whatever you want to call it? and when it goes over that 25% it kicks into the next percentage column?
ALL BE ADVISED!
The amount that you correct on the DTEC in the fuel map does not equate to a % of fuel leaned. It's JUST a Value. Use you WB to see the results ONLY.
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
Old 01-22-2008, 12:46 PM   #62 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Correctamundo!
Actually it extrapolates the value linerally to the next load point.
0-25 25-50 50-75 75-100
And it is LOAD that those values represent.
Old 01-22-2008, 04:35 PM   #63 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (27)
Quote: Originally Posted by mario03srt View Post
Correctamundo!
and LOAD is boost right?
SkittlePower is offline   Reply With Quote
Old 01-23-2008, 05:55 AM   #64 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Not exactly, they are 2 different things.
You can hit a part throttle boost of 12 psi on the flat hiway and not load the motor a lot, but go up a hill with a couple of guys in the car and 8 psi of boost and the engine is loaded more. WOT on the hiway with only you in the car and the engine is fully loaded because it is digging so hard.
Bring up your fuel map while driving and watch the cursor travel thru rpm and load scales during boost, that will illustrates this pretty well. The DTEC takes TPS, Map Voltage (Boost), RPM and calcs the load.
Old 01-23-2008, 03:50 PM   #65 (permalink)
Trader Rating: (27)
but the dtec doesnt see tps signal, it sees map signal and the rpm, while the tps wire on the dtec gets wired in with the map signal per the how to.
i was very leery about this when i installed, but i just did it, since the dtec wont alter the tps signal if you dont tell it to.
Old 01-23-2008, 06:01 PM   #66 (permalink)
dirtyd99's Avatar
Member Number: 38128
ok i am officially confussed now. i thought it was phisically reading the map sensor(not throttle position) but was translating(calculating) it into the tps siganal in which youll be able to edit the map accuratly.
I WOT shift my lawn mower.
dirtyd99 is offline   Reply With Quote
Old 01-23-2008, 08:18 PM   #67 (permalink)
Spunjah413's Avatar
Member Number: 41050
Quick Question. Im currently tuning a buddies car. He's on 750's and No returnline, 60trim. He doesn't have a scan gauge yet, so im not sure what his timing looks like at all. Im already pulling in the -30+%, and im a lil nervous to pull more than that. Currently hes at 11.2ish AFR from 4-6k, but from 3-4 hes in the 9's for AFR with -37 on the DTEC. Should i be worried to pull anymore until he gets his scan gauge?
Spunjah413 is offline   Reply With Quote
Old 01-23-2008, 09:41 PM   #68 (permalink)
gotboost?'s Avatar
Member Number: 2384
Get a returnline. Without being able to adjust the amount of fuel he's running, you're gonna run into problems. A scan gauge would be beneficial, but if he doesn't have enough money to get both of them, get the returnline first. That's my opinion at least.
gotboost? is offline   Reply With Quote
Old 01-25-2008, 06:38 AM   #69 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Yes. Be worried.
Don't exceed the high 20's in correction. DTEC and 750's are not the optimum setup.
Get a returnline and drop the FP to the low 40's.
They car will still haul arse in the high 9's low 10's afr. Thats how they come from the factory.
FYI,
Marion
Old 01-25-2008, 06:42 AM   #70 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Yes that right.
Old 01-27-2008, 06:40 PM   #71 (permalink)
Trader Rating: (27)
so i finally got off my ass and calibrated my knock/shift light......
so i went out to test whether the shift point was right, and when i got on it, right when i hit full boost the knock light lights up red, which means moderate/severe knock. so i went to the dtec and opened knock on the gauge, and tried it again, and i got 1 count. now im not an expert on knock, but i dont think 1 count is severe.
if this is not a big deal, how do i desensitize the knock sensitivity so that it doesnt happen like that but will still alert me when damaging knock is present?
Old 01-27-2008, 07:34 PM   #72 (permalink)
Member Number: 58932
i shoved the knock light under my dash.
its nothing more than eye candy. you can not EVER properly gauge knock correctly w/ the DTEC knocklite.
Old 01-27-2008, 07:51 PM   #73 (permalink)
Trader Rating: (27)
well is there a way to turn the knock part off? so you just get the shift light?
Old 01-27-2008, 09:58 PM   #74 (permalink)
dirtyd99's Avatar
thats actually a good question cuz i was thinking the same thing.
Old 01-27-2008, 10:07 PM   #75 (permalink)
im not sure. i'd have to check my owner's manual in the car.
worse comes to worse, you could de-sensitize the knock-lite so much that it wouldnt really every come on.
