Old 01-16-2008, 01:10 PM   #46 (permalink)
StRicTly4boosting's Avatar
Member Number: 17164
Trader Rating: (13)
Quote: Originally Posted by gotboost? View Post
So which wire is the ground and which is the power? Were your wires blue and white like the one in the pic?
Call turboxs 301-977-4727
And find out and post them on here for us if you can im at work =/
Mopar Stage 3 w\Toys , Mopar Short Throw Shifter, Agp S3 Wastegate, Agp MotorMounts, Agp Return Fuel line w\ Aeromotive Gauge , Needswings 3inch Downpipe delete cat w\CutOut , Dc-Sports CatBack Exhaust , Mpix Fmic , Jmb Pressure Pipes with Hks SSQ Bov , Walbro 255lmph Fuel Pump , $20Catch Can, D-tec Fuel Computer & Dtec TunerBox , Autometer 30\30 BoostGauge , Mopar Stage 3 Coilovers , Dc-Sports Front Strut Bar , Prothane Bushings on Control Arms
StRicTly4boosting is offline   Reply With Quote
Old 01-16-2008, 05:57 PM   #47 (permalink)
gotboost?'s Avatar
Member Number: 2384
Called 3 times today, first time, the person who could have helped me was at lunch. Second time, he was busy on a car and third time, it was 3 minutes after they closed
I've got a voltmeter handy, but don't know how I would go about trying to check which is the positive and which is the ground. If anyone who knows how to go about doing that could explain, I would be more than happy to post the results.
gotboost? is offline   Reply With Quote
Old 01-16-2008, 06:45 PM   #48 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (24)
Quote: Originally Posted by NoisufnoC View Post
basically.
thats the voltage range for the stock and the stage 2/3 map sensor. see how 0 boost is 2.08v?
i know that, i have the chart even on my phone and printed out.
so when im setting the parameter for the lowest point, i should go to the auto option to see what the mV is at then set it a little lower right?
and for the 100% end, should i hook up the boost leak tester and pump say 25psi in the system and do the same as above but just for the max voltage?
SkittlePower is offline   Reply With Quote
Old 01-17-2008, 05:39 PM   #49 (permalink)
Trader Rating: (13)
looks like me and you have the same prob ... i just got my tunerbox back from turbo xs ... its always the girl who picks up rite?? ... well anyways talk to some 1 named Jermaine he was the 1 who helped me out he is a nice guy he told me which wires were which .. i think thats why i had a fuse go bad i connected it wrong so just double check ill call them again 2morrow to find out ... i cant believe they dont even have a diagram .. shit sucks
Old 01-18-2008, 07:27 AM   #50 (permalink)
gotboost?'s Avatar
Member Number: 2384
Well, which wires are which? If he told you, why make me call them? What's the white and what's the blue?
Old 01-18-2008, 07:41 AM   #51 (permalink)
Trader Rating: (13)
i fogot he told me .. im goin to call back im at work ill call them at lunch time ....
Old 01-18-2008, 08:54 AM   #52 (permalink)
NoisufnoC's Avatar
Member Number: 136
no. set your lowest point for 0 mV and you highest point at 4000mV (for stock / stage 1)
i'm about 98% sure thats right...i'll have to look at my DTEC to make sure.
omgz!! i haz mods!!
Old 01-18-2008, 10:03 AM   #53 (permalink)
Trader Rating: (13)
Just got off the phone with Turbo XS
BLUE = POWER
WHITE = GROUND
I will be installing it real soon and have pics up ...
Old 01-18-2008, 10:04 AM   #54 (permalink)
Trader Rating: (13)
I'm on stage 3 and have the TPS SET TO 3500rpm MAX
On the parameter i have it set to 5000mv low and high .. i never touched that tho but my car still runs fine ....
Old 01-18-2008, 05:16 PM   #55 (permalink)
Trader Rating: (13)
my wideband box works into the dtec i even uploaded the files !!! way much easier to tune now ...
Old 01-18-2008, 07:49 PM   #56 (permalink)
Trader Rating: (24)
cool man. keep us posted
Old 01-18-2008, 09:22 PM   #57 (permalink)
gotboost?'s Avatar
Member Number: 2384
BLUE = POWER
WHITE = GROUND
Thanks for posting. I called them myself and finally talked to someone. Was gonna come on here and post it when I noticed you already had. He said about 100 units went out with the blue and white wiring instead of the normal red and black. Anyway, the other question I have, the little black 2 prong plugin that is on the harness, does that go into the 2 prong on the side where the phone jack is? Just wanted to make sure it wasn't for something else.
Old 01-19-2008, 12:09 AM   #58 (permalink)
BeauM0507's Avatar
Member Number: 35892
So I sent my DTEC FC off to Turbo XS for replacement January 3rd; as you know today is January 19, how long does it usually take for them to send a damn replacement?
Turbonetics T3/T04 50 Trim Powered
BeauM0507 is offline   Reply With Quote
Old 01-21-2008, 08:33 AM   #59 (permalink)
NoisufnoC's Avatar
Member Number: 136
nice. its the tuner box, right? switch your gameboy to the gauge screen and flip to AFR, and tell me if there's a delay between what your wideband says and what the "gauge" on the gameboy reads. mine has one, and i can't figure out if theres a way to fix it.
what'd you upload?
Old 01-22-2008, 12:39 PM   #60 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
They have sent me 2 replacements in 10 days w/o even a return. The 2 replacements were junk.
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
