Old 01-09-2008, 08:32 PM   #31 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (27)
Quote: Originally Posted by dirtyd99 View Post
^where to adjust the sensitivity?
when you are at the home page, go to the option to calibrate or whatever its called where you can edit the map input as map or maf, and go to knock after that, and you will have a sensitivity option. also if you go to the turbo xs website, you can download the instruction manual, and in there it tells you how to calibrate the knock light. its just a few series of pressing the button on the light and revving the motor.
SkittlePower is offline   Reply With Quote
Old 01-10-2008, 07:43 PM   #32 (permalink)
dirtyd99's Avatar
Member Number: 38128
^ thanks for the info pedro. i dont have the manual thats why i asked.
I WOT shift my lawn mower.
dirtyd99 is offline   Reply With Quote
Old 01-10-2008, 08:43 PM   #33 (permalink)
Trader Rating: (27)
Turbo XS - Software updates <<<here is the page to download the manual. takes just a few seconds. theres lots and lots of info there. hope it helps!
Old 01-12-2008, 11:53 PM   #34 (permalink)
Trader Rating: (27)
ok another question. how do you set parameters on the inputs so that you can tune a low throttle/around town map since its based on boost and not throttle position?
Old 01-15-2008, 01:46 PM   #35 (permalink)
NoisufnoC's Avatar
Member Number: 136
look at your map while the car is idling. you'll see a box that shows you where you are on the map. 0 volts on our map sensor is not 0 psi, so when you're off throttle in vac, you're sitting in the 25% column of the dtec map.
omgz!! i haz mods!!
Old 01-15-2008, 05:49 PM   #36 (permalink)
Trader Rating: (27)
ok, so say just for shitts and giggles i set the 25% side to -5%. will it pull 5% of fuel from anything lower than 25% boost/throttle whatever you want to call it? and when it goes over that 25% it kicks into the next percentage column?
Old 01-15-2008, 06:24 PM   #37 (permalink)
gotboost?'s Avatar
Member Number: 2384
I believe that's how it works Pedro.
On a side note, I just got my tuner wideband. For someone reason, Turboxs doesn't send instructions with it. I went to their website and it seems somewhere along the way, they changed the design of the tuner. Anyway, in the instructions, it says to hook the red wire to a 12v switched power and the black wire to a ground. My issue is, my harness for the tuner has neither a red or black wire. It's got a blue and white wire.
It looks like this guys.
Anyone know which wire is supposed to be the white and which is the blue?
gotboost? is offline   Reply With Quote
Old 01-15-2008, 07:26 PM   #38 (permalink)
Trader Rating: (27)
you can try to hook it up to a multimeter and test it to see which pulls power and that will be your 12v wire
Old 01-16-2008, 08:29 AM   #39 (permalink)
StRicTly4boosting's Avatar
Member Number: 17164
Trader Rating: (15)
thats my picture lmao .... thats funny i had problems with my tunerbox i had to get it sent out i couldnt get it to work .... and turbo xs still has it i should be knowing when i should be gettin it back .... it sucks that nobodyhas the instructions for that type of tunerbox ... ...
Mopar Stage 3 w\Toys , Mopar Short Throw Shifter, Agp S3 Wastegate, Agp MotorMounts, Agp Return Fuel line w\ Aeromotive Gauge , Needswings 3inch Downpipe delete cat w\CutOut , Dc-Sports CatBack Exhaust , Mpix Fmic , Jmb Pressure Pipes with Hks SSQ Bov , Walbro 255lmph Fuel Pump , $20Catch Can, , Autometer 30\30 BoostGauge , Mopar Stage 3 Coilovers , Dc-Sports Front Strut Bar , Prothane Bushings on Control Arms
StRicTly4boosting is offline   Reply With Quote
Old 01-16-2008, 08:31 AM   #40 (permalink)
NoisufnoC's Avatar
Member Number: 136
weird.
i've got the tuner pro box, my only gripe with it is the fact that the damn thing is about the size of a single DIN radio...but other than that it works like a charm.
Old 01-16-2008, 08:33 AM   #41 (permalink)
NoisufnoC's Avatar
Member Number: 136
basically.
thats the voltage range for the stock and the stage 2/3 map sensor. see how 0 boost is 2.08v?
Old 01-16-2008, 11:29 AM   #42 (permalink)
gotboost?'s Avatar
Member Number: 2384
Quote: Originally Posted by NoisufnoC View Post
weird.
So which wire is the ground and which is the power? Were your wires blue and white like the one in the pic?
Old 01-16-2008, 11:31 AM   #43 (permalink)
NoisufnoC's Avatar
Member Number: 136
no mine were red and black.
you've got a 50 50 shot
lol
Old 01-16-2008, 11:42 AM   #44 (permalink)
NoisufnoC's Avatar
Member Number: 136
what version of the DTEC software is everyone running?
Old 01-16-2008, 12:02 PM   #45 (permalink)
dirtyd99's Avatar
im running v1.07
