Old 01-08-2008, 04:55 PM   #16 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (27)
Quote: Originally Posted by NoisufnoC View Post
I tried starting a part 2 thread a while back, but no one really posted.
we should merge our info into one thread.
DTEC Discussion/Help Thread II
yeah, we should keep bumping them until some people help us, then put them together, cuz we dont have a lot of info, and the stickied one is 90 pages of post whoreing
SkittlePower is offline   Reply With Quote
Old 01-08-2008, 08:00 PM   #17 (permalink)
dirtyd99's Avatar
Member Number: 38128
how did you wire it?
i wired it the way the stickey said. the puple wire is the one that goes to the wire that is white with the blue stripe on the orange plug to the ecu. everything else works except for that one.
I WOT shift my lawn mower.
dirtyd99 is offline   Reply With Quote
Old 01-08-2008, 08:07 PM   #18 (permalink)
dirtyd99's Avatar
on a second note, i didnt not know how much knock i have on on a stock turbo at 15psi EVEN WITH NOS OCTAIN BOOSTER. its depressing!
Old 01-08-2008, 08:10 PM   #19 (permalink)
goats srt's Avatar
Member Number: 47689
um...
Old 01-08-2008, 08:31 PM   #20 (permalink)
Trader Rating: (27)
dude, ditch the octane booster. have you ever read the back label? each bottle will treat like 10 gallons, and it says it increases octane by like 7 points, which later in the text it says that 10 of those points equals one full octane point, its a waste of money, its a gimic. and if you have a lot of knock on stock turbo at 15psi, you might have a lot of boost leaks, or you might need to recalibrate the parameters in the dtec for knock.
Old 01-08-2008, 08:53 PM   #21 (permalink)
dirtyd99's Avatar
i just might need to recalibrate it. i did all of what the the sticky said but maybe im missing something. i bought it used also and i zerod out everything. the nos race booster has more like 25 points or somthing like that but yeh its a waist of money. i looked at it like every little helps.
Old 01-09-2008, 08:52 AM   #22 (permalink)
NoisufnoC's Avatar
Member Number: 136
on the DTEC? the knock reading is super sensitive out of the box. I was seeing 2 to 3 counts of knock at idle according to the dtec, but my aeroforce gauge was happy, so i turned down the sensitivity and all is well.
omgz!! i haz mods!!
Old 01-09-2008, 09:47 AM   #23 (permalink)
StRicTly4boosting's Avatar
Member Number: 17164
Trader Rating: (15)
Speaking about the knock light , i actually datalogged it 1 day and i notice that when im on 93 octane from 3000rpm to redline in a 3rd gear pull i noticed that the knock reads counts of 10 to as high as 30 @ 24psi on my stage 3 .... well when im in HOM and im on C16 AT @24PSI i barely read any knock ill get 5 or 6 if im lucky in the same gear at the same rpm all the way til redline so my guess is that the knock actually reads right somewhat... i have so many questions and im happy that this thread was open there was alot of un answreed questions ive had to ask that i couldn't get an answer so hopefully nobody post-whores this one...
Mopar Stage 3 w\Toys , Mopar Short Throw Shifter, Agp S3 Wastegate, Agp MotorMounts, Agp Return Fuel line w\ Aeromotive Gauge , Needswings 3inch Downpipe delete cat w\CutOut , Dc-Sports CatBack Exhaust , Mpix Fmic , Jmb Pressure Pipes with Hks SSQ Bov , Walbro 255lmph Fuel Pump , $20Catch Can, , Autometer 30\30 BoostGauge , Mopar Stage 3 Coilovers , Dc-Sports Front Strut Bar , Prothane Bushings on Control Arms
StRicTly4boosting is offline   Reply With Quote
Old 01-09-2008, 11:35 AM   #24 (permalink)
NoisufnoC's Avatar
Member Number: 136
i dont deny that the knock sensor is somewhat correct, i just think that its more sensitive than our stock knock sensor.
Old 01-09-2008, 11:53 AM   #25 (permalink)
Member Number: 45790
Trader Rating: (12)
I'd say your DTEC is reading knock wrong. You should also make sure your stock knock sensor is tightened good. If you showing that much knock and it's actually true I'd say your motor would be toast by now. Even 5 to 6 knock is considered too much. are you holding HOM throughout the gears or does it cut out. If your holding it than your def. getting a wrong Knock reading. Usually knock occurs in the higher rpms not at like 3000 i'd say your getting a falty reading.
Tzone is offline   Reply With Quote
Old 01-09-2008, 12:24 PM   #26 (permalink)
dirtyd99's Avatar
that makes a valid point.
Old 01-09-2008, 03:42 PM   #27 (permalink)
Trader Rating: (27)
the dtec doesnt have its own knock sensor, it utilizes the stock one, and it is very sensitive from the factory settings. the pcm has complex logarithms that filter out noise and vibrations when monitoring the knock sensor, which the dtec is similar, but you have to set how sensitive it is, especially if you have solid mounts, remove the bs chain, etc.
Old 01-09-2008, 05:32 PM   #28 (permalink)
dirtyd99's Avatar
^where to adjust the sensitivity?
Old 01-09-2008, 05:50 PM   #29 (permalink)
Trader Rating: (15)
yes im holding hom all the way to redline on Sunoco C16
My settings are at 0 on edit maps I'm waiting to get my tuner wideband repaired...
( Example as what it is close )
Sunoco C16 @ 23-24PSI TO REDLINE
3000RPM = 0
3500= 0
4000= 0
5000= 2
5500= 4
6000= 8
6500= 4
93 PUMP GAS @ 22LBS
3000RPM = 4
3500= 8
4000= 18
5000= 22
5500= 22
6000= 23
6500= 19
As far as holding HOM I notice that if i press the HOM button and im on 93 i will hold high octane mode til about 4000 rpm if i start from 2900rpm and up as soon as i get to 4000 i read 30 and its usually around 25-30 on the knock where i usually get kicked out of HOM for good and then it drops back down to like 10-15 on knock and rises .. i datalog it so i see how everything works ...
Old 01-09-2008, 08:29 PM   #30 (permalink)
Trader Rating: (27)
^^have you tried to calibrate the knock light via the instructions from turbo xs?
