Old 06-10-2008, 09:39 PM   #1 (permalink)
Big Corey's Avatar
Member Number: 58459
Trader Rating: (33)
Default dtec calibration
i installed my dtec and i can get it to adjust and run fine with my stage1 injectors but when i put the 650s in the car wont even idle thinking its not calibrated rite for the bigger injector but not sure can anyone help????
AGP3147 ,QW BFMIC,Atp hard pipes,HKS bov,3 in maxfab dp without cat,greddy evo2 catback stage2,many other mods to come
FORSALE:Boomba STS & WTT:stage2 injectors for 650s
Big Corey is offline   Reply With Quote
Old 06-10-2008, 10:59 PM   #2 (permalink)
roberto's Avatar
Member Number: 39538
Trader Rating: (18)
I don't beleive that there is a calibration for the size of injectors...you might need to pull more fuel to compensate for the new amount of fuel.
Roberto
Stage 2/3 Hybrid
360whp - 388wtq
roberto is offline   Reply With Quote
Old 06-11-2008, 08:35 AM   #3 (permalink)
Big Corey's Avatar
Trader Rating: (33)
im already pulling as much as the dtec will let me
Old 06-11-2008, 08:48 AM   #4 (permalink)
tamadx's Avatar
Member Number: 26290
Trader Rating: (18)
reset your comp
S3, WGA, Return Line, CAI, Turboback, BFMIC, 55mm TB, DTEC, Wideband, W/I, Scan Gauge, Ported Stuff
tamadx is offline   Reply With Quote
Old 06-11-2008, 08:59 AM   #5 (permalink)
Big Corey's Avatar
Trader Rating: (33)
i have reset it and it still does the same thing its like when i put the bigger injectors in the dtec quits working
Old 06-11-2008, 09:08 AM   #6 (permalink)
roberto's Avatar
Trader Rating: (18)
do you have a returnline? If you do are you running 'static' or 'source'? Either way, if you have a returline what is your base pressure at?
Old 06-11-2008, 09:15 AM   #7 (permalink)
Big Corey's Avatar
Trader Rating: (33)
no returnline
Old 06-11-2008, 03:24 PM   #8 (permalink)
Big Corey's Avatar
Trader Rating: (33)
have heard not to connect the blue and green wire is this correct
Old 06-12-2008, 10:47 AM   #9 (permalink)
tamadx's Avatar
Trader Rating: (18)
the blue wire gets tapped in the green wire if i remeber correctly....dont quote me on that...but one of those connects to your map signal....again if i remeber correctly....i can check the car sometime and see how i have it hooked up.
Old 06-12-2008, 04:36 PM   #10 (permalink)
Big Corey's Avatar
Trader Rating: (33)
i connected the blue and green when i hooked it up
Old 06-13-2008, 09:45 AM   #11 (permalink)
tamadx's Avatar
Trader Rating: (18)
but after that i think the green wire goes to the map signal with the blue wire attached to the green wire....
Old 06-13-2008, 10:46 AM   #12 (permalink)
Big Corey's Avatar
Trader Rating: (33)
i didnt see anything about that in the directions
Old 06-13-2008, 11:56 AM   #13 (permalink)
Big Corey's Avatar
Trader Rating: (33)
i reread everything and the blue wire taps into the green and i wired them together at the end so thats prolly the problem
Old 06-14-2008, 08:46 AM   #14 (permalink)
Member Number: 59653
What you need to do is go to RPM and Hit auto CALB and REV THE motor 2 grand and hit A on the GBA it should set your RPM to a different setting then your stock motor settings. If that dont work apply your RPMS on your DTEC MAPS on the LEFT so hold the <<< on the GBA on the pad. There you can set your cut at a RPM if you have it around 500 RPM it will do a shitty RPM IDLE I had the same prob... Try that if nothing helps come to are site and download the Manual for the DTEC you have on are forums. NeonDtecEquipment - Dtec,Dtec Repair, ETC. ..
PS. When you make changes save them and when it takes you back where you can select maps hit the start button to save it again then turn car off and DTEC OFF. The turn DTEC on after 5 mins and trun the car so your dtec can be read and your cd player comes on. Dont turn the motor on. Let it sit there for few then turn it off. Wait about 5-10 mins. Then try your DTEC with the car on but turn the DTEC ON FRIST before turning on the car...
Click Here to Enter The site.
http://www.tuningneons.com
dtecneon is offline   Reply With Quote
Old 06-14-2008, 11:45 AM   #15 (permalink)
Big Corey's Avatar
Trader Rating: (33)
but will the car run with 650s and no retunline
» Search Used Cars
Page generated in 0.27280 seconds with 11 queries
