Old 07-13-2008, 04:34 PM   #1 (permalink)
Member Number: 65464
Default Current Cobalt Owner: Want to know what tuning software SRT4's use
hey guys,
i currently own a cobalt ss... and we have hptuners used as our primary tuning software....but from what i can see hptuners is not supports srt4's as of yet (or are they?)
can someone point me in to right direction as to what software would be needed?
thanks!
kibosh3 is offline   Reply With Quote
Old 07-13-2008, 09:11 PM   #2 (permalink)
OH5SRT4's Avatar
Member Number: 21866
Trader Rating: (19)
Most guys here run piggybacks such as an safc2, dtec, etc. AEM offers a standalone for our car and SCT now offers stock computer reflashing. There is no "software" per say that you can just hook your laptop up to your car and tune the computer.
2005 Black SRT-4
Mods: 3" O2 housing/Maxxfab DP, Mopar Catback, CCA FMIC, AGP CAI, BWoody Tranny/Motor Mounts, Hotchkis Springs, HKS BOV, Kinetic WGA, Mopar STS, AEM Wideband, PTP Check Valve, JMB Catch Can, 180 T-Stat, MSD Wires, CF OEM Hood, Black Housing Headlights
XBL Gamertag: The Hammerman37
OH5SRT4 is offline   Reply With Quote
Old 07-13-2008, 09:19 PM   #3 (permalink)
looks like i have some serious learning to do then...i see many really heavily modded srt's ...and i wonder, with all the mods that the car has, how is the car tuned to be able to handle and adapt to them?
like say, the owner changes to the stock turbo for a 50 trim...how would the tune be taken care of?
Old 07-13-2008, 09:21 PM   #4 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (28)
Big injectors and a piggy back (safc, dtec, etc) or like was stated earlier standalone or sct
bpsrt4 is online now   Reply With Quote
Old 07-13-2008, 09:35 PM   #5 (permalink)
thanks for the info, guys
Old 07-13-2008, 09:38 PM   #6 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (65)
see the concept you have to understand is that GM uses software that isnt self learning so if you add mods you have to modify the software for the new hardware. The SRT4s software allows the car to continuously adapt based on what it reads from the sensors BUT the catch is it can only do so much. When you reach that point you toss in some form of piggy back or just use a flash type tuner.
Currently option to "tune" and srt4 are:
Piggyback:
map clamp- cheap, unreliable and simple way to make more power
APEXi SAFC ver.1 or 2/Neo-...very widely used yet extremely effective
Greddy Emanage-....not cheap but effective when installed/tuned properly
Turbo XS DTEC-....again not cheap but effective when installed/tuned properly
AEM FIC-...bugs are being worked out but it should prove quite usefull
Flash:
SCT
Diablo Predator (will be out soon)
Standalone:
Electromotive TEC3
AEM EMS
Megasquirt
or
using a Mopar Stage 1,2 or 3 pcm or a custom calibrated pcm from B&G Performance
Built by experts. Tested in the real world.-Mopar
For sound Install/Tuning assistance: (727)512-9684 or PM
Now serving Upstate SC/N. GA SRT4 community
<---My modest 305fwhp "project" car in progress
NeonDan is online now   Reply With Quote
Old 07-13-2008, 10:01 PM   #7 (permalink)
so, hypothetically speaking - if i were to add in meth injection and nitrous, i could pick up and apexi S-AFC and it would calibrate it from there?
sorry, im somewhat confused as to what a piggyback actually does...do they trick the car's ecu? can i increase timing with the S-AFC?
Old 07-14-2008, 03:14 AM   #8 (permalink)
rasp's Avatar
Member Number: 56076
HPTuners is in the process of making an SRT-4 compatible tuning software. IMO that will blow all the other competition (including the EMS) out of the water. I used HPTuners on my GTP and that software is fucking amazing.
Old 07-14-2008, 04:05 AM   #9 (permalink)
Nelson's Avatar
Member Number: 52787
No, SAFC is used to take away fuel at RPM points.
Stage Slow...
It's gone... Back to Stock For Realz
Nelson is online now   Reply With Quote
Old 07-14-2008, 04:07 AM   #10 (permalink)
rasp's Avatar
As said above, the SAFC simply removes fuel by "tricking" the ECU. No other parameters can be "tuned" with the SAFC.
Old 07-14-2008, 04:10 AM   #11 (permalink)
Nelson's Avatar
Unless you go with an SCT or EMS, there isn't software used to add or take away timing from the SRT PCM.
Page generated in 0.17615 seconds with 11 queries
