Old 09-24-2009, 02:18 PM   #1 (permalink)
rsanson21's Avatar
Member Number: 69344
Default Can i Run 20 psi on a stage 2?
I got a stage 2 wo toys (stock mopar tune) and was wondering if i can raise the boost to 20 psi, now i spike 18 but hold 15-16 to redline,im getting the dsp next week and was wondering if i can raise the boost with that or through the wga,also my afr at wot is 10.3,should i lean it with the dsp or just raise the boost?
rsanson21 is offline   Reply With Quote
Old 09-28-2009, 12:59 PM   #2 (permalink)
duster360's Avatar
Member Number: 45182
Get the DSP, load its 93 tune and test it.
A/F will be leaner but I'm not 100% what the boost will look like out of the box.
Regardless of what the boost is, you can easily raise and lower it with the DSP.
DO NOT ADJUST BOOST WITH THE WGA.
Old 09-30-2009, 07:21 AM   #3 (permalink)
KrazyRdR83's Avatar
Member Number: 55270
Trader Rating: (40)
i will say yes...but idk if you can with the stage 2 wga. i have a buddy with stage 2 no toys, agp wga, and dsp, loves it. last i spoke to him, he'll spike 21, and hold 18 and still run high 10's - low 11's a/f without touching the WOT fuel table
04 Neon SRT-4 - lifetime project
99 R1 - DD
02 Night Train
04 XL883
00 B5 Passat - POS!
KrazyRdR83 is offline   Reply With Quote
Old 10-01-2009, 03:16 PM   #4 (permalink)
sareteafour's Avatar
Member Number: 73170
im also planning on getting a dsp, and ur saying that adjust the boost from the dsp not the wga, where should the wga setting be left at?
Stage 2, 3bar map/tip, AGP WGA, NGK Iridiums 1 step colder, Walbro 255lph, Mopar CAI, GReddy Catchcan, MSD wires, Stock coilpack, GReddy turbo timer, DC Sports strut bars, Hotchkis sway bars, KW V1, AGP solid mounts.
sareteafour is offline   Reply With Quote
Old 10-01-2009, 03:28 PM   #5 (permalink)
duster360's Avatar
If you're unfortunate enough not to be running PCM boost, adjust your wga where you like.
imo an S2 PCM should run a S2 wga with DSP/PCM boost control.
An AGP(or any aftermarket wga) has 0 advantage over an S2 wga and only the slighest advantage over a stock wga
Old 10-01-2009, 09:07 PM   #6 (permalink)
jojo's Avatar
Member Number: 41485
i have a s2 with an agp wastegate it will spike 20psi and hold 18psi to redline I think when i toon it will hold 20psi till redline
jojo is offline   Reply With Quote
Old 10-01-2009, 09:10 PM   #7 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
run 22psi and youll be golden
AGP S256 FS
Old 10-02-2009, 06:54 AM   #8 (permalink)
duster360's Avatar
I'll give you $10 if you can show me a datalog of you holding more then 16.99psi at 6000rpm.
Old 10-02-2009, 07:04 AM   #9 (permalink)
SNOOPALOOP's Avatar
Member Number: 29605
Trader Rating: (23)
Yeah, on stock turbo I call BS holding 20 to redline
SNOOPALOOP is offline   Reply With Quote
Old 10-02-2009, 07:27 AM   #10 (permalink)
SRTtypG's Avatar
Member Number: 7146
if anyone thinks they hold boost, just look at the thread started by duster lf data logs to see how much boost people really hold. its great, i love it. for all the people who claim """this wga""" with XXXX spring holds more boost then urs lol. last i lookd it was at like 16.3lbs or something like that. its great
s2,agp wga, aem short ram, hard pipe with greddy type s, 3inch dp with qtp cut out, fmic,agp solid mounts, nex coil overs,turbo timer, front and rear strut tower bars, catch can... all that i can remember right now
SRTtypG is offline   Reply With Quote
Page generated in 0.15723 seconds with 13 queries
