Old 07-21-2008, 12:52 PM   #1 (permalink)
krnlscott's Avatar
Member Number: 25712
Default Can a 3 bar MAP sensor throw boost readings off?
I have a 3 bar MAP sensor, Autometer 30 psi boost gauge, and an Aeroforce scan gauge. My boost gauge has a dent in it from being dropped once. Well the boost gauge is reading 20 psi but the scan gauge is reading 13 psi. I'm not sure which gauge I should believe but I would think that the scan gauge would be more accurate since it gets that reading directly from the MAP sensor. The boost gauge is using the line from the stock one. But I just don't know if it's possible for the car to pull this hard on 13 psi.
krnlscott is offline   Reply With Quote
Old 07-21-2008, 12:53 PM   #2 (permalink)
NoisufnoC's Avatar
Member Number: 136
what PCM do you have?
Do you have any type of piggy back fuel controller (SAFC, DTEC, etc)?
omgz!! i haz mods!!
Old 07-21-2008, 01:55 PM   #3 (permalink)
krnlscott's Avatar
Stock, stage 0 PCM. Using SCT PRP for tuning.
Old 07-21-2008, 01:57 PM   #4 (permalink)
NoisufnoC's Avatar
Member Number: 136
Is your SCT Map scaled for the 3 bar map and 3 bar tip?
Old 07-21-2008, 03:19 PM   #5 (permalink)
krnlscott's Avatar
Yes it is.
Old 07-21-2008, 05:15 PM   #6 (permalink)
NoisufnoC's Avatar
Member Number: 136
Then i have no idea
Old 07-26-2008, 02:51 PM   #7 (permalink)
krnlscott's Avatar
Not much input besides make sure the SCT map is scaled huh....
Page generated in 0.13788 seconds with 11 queries
